Go to Post I will test first 'cause you cannot learn unless you break something first! - Andy Brockway [more]
Unread 05-02-2010, 16:40
railerobotics's Avatar
railerobotics railerobotics is offline
FRC #0935
railerobotics will become famous soon enough
pic: Team 935 Chassis Teaser
Unread 05-02-2010, 16:41
Thermal's Avatar
Thermal Thermal is offline
Drive Team Coach
AKA: Ryan Brown
FRC #1293 (D5 Robotics)
Thermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to behold
Re: pic: Team 935 Chassis Teaser
1/4" alu huh? Interesting choice i'd say, I don't think too many chassis are made out of alu that thick. How heavy is it?
Unread 05-02-2010, 16:43
How are those mecanums working out as turning aids?
Unread 05-02-2010, 16:45
gyaniv's Avatar
gyaniv gyaniv is offline
AKA: Gutman Yaniv
FRC #2230 (General Angels)
gyaniv has a spectacular aura aboutgyaniv has a spectacular aura about
What benefit do you get from the mechanum wheels if you have another 2 plaction wheels with wedgetop tread on them at each side?... won't it be better if you put 2 omni wheels instead?
FRC Team 2230 - Student - 2009-2011
FRC Team 2230 & 4406 - Mentor - 2012
FRC Team 2230 - Mentor - 2013-present
"A mentor's job is to understand what the students are trying to make, and bend the laws of physics to make that happen"
Unread 05-02-2010, 16:47
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
It's hard to tell exactly, but judging by the frame, the center two wheels are raised up slightly, so that on normal flat ground they're running straight mecanum, but when they go over the bump the traction wheels are there to help out.
Unread 05-02-2010, 16:52
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
That was my take on it as well. They have a mecanum drive that is built to transverse the bump. And given the short distance between the wheels, they can do it with an awfully low ground clearance (and drive system in general), which can help with their CG.
Nice work.
Unread 05-02-2010, 16:58
gyaniv's Avatar
AKA: Gutman Yaniv
You might be right... Though it doesn't seems so because the holes in the chassis for the bearings looks like they are in one line, and that both wheels are 8"... but hard to judge from this pic...
I heard of some times having trouble getting over the bump with regular mecanum wheel, since their robot slipped because the wheels didn't have enough traction.. so If it is what they did then it's a great idea, though even one wheel will be enough to help the mecanum climb over the ramp.
I would love to see a team "Reforging" a mecanum wheel and putting wedgetop tread on the small wheels
Unread 05-02-2010, 17:00
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Look at the center support struts on each side of the bearings. You can see that the middle two are higher than the end two. The middle two wheels are raised.
Unread 05-02-2010, 17:02
abeD's Avatar
abeD abeD is offline
FRC #4707 (Mentor FRC#4707 Alumni FRC#710)
abeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to behold
They are definitely not in line, looks between .25 and .5 inch raised middle wheels. If you look closely at the bearing then follow the horizontal line you will see it.
edit: beaten to it...
Penn Class 08
Unread 05-02-2010, 17:05
IndySam's Avatar
IndySam IndySam is online now
FRC #0829 (Digital Goats)
looks sweet!
Are you guys planning on shims for bumper supports so those screws and bearings are inside the frame perimeter?
Unread 05-02-2010, 17:06
keericks's Avatar
keericks keericks is offline
AKA: Kent
FRC #1671 (Buchanan Bird Brains)
keericks is a glorious beacon of lightkeericks is a glorious beacon of lightkeericks is a glorious beacon of lightkeericks is a glorious beacon of lightkeericks is a glorious beacon of light
Actually, if you look closer, the centerline (CL) for the bearings are not in a line. Look at the horizonal "web" frame structure going through the mec wheel bearing CL ... now follow it over to the first traction wheel. Notice the jog in the frame structure upward, and that new web centerline passes through the two center traction wheels, confirming the earlier post of high centered traction wheels for bump assist. Cool design.
Unread 05-02-2010, 17:07
KC1AJT's Avatar
KC1AJT KC1AJT is offline
Head Mentor
AKA: Patrick
FRC #6617 (Bellinghan High School Black Hawks Robotics Club)
KC1AJT is an unknown quantity at this point
if you look at the second plaction wheel there is a shadow under it, that is exactly what they are doing
Mentor - Team 6617
_____________________________________________
Student Years - Team 61
2011 Boston Regional
2011 BAE Systems/Granite State Regional
2010 Northeast Utilities FIRST Connecticut Regional Finalist
2010 Boston Regional
2009 Archimedes Division
2009 Connecticut Regional
2009 Boston Regional Regional Winner
Unread 05-02-2010, 17:08
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
My guess is that they are not running straight mecanum on a flat surface.
The plaction wheels with treads are more than 8". Compare them side by side even with AM 8" omniwheels and they are definitely not the same height.
We ran the same setup with omniwheels on the end and they dont even touch the ground.
Correct me if I'm wrong, but is 935 doing this to get all 4 wheels on the ground, with a better turning ability?
Unread 05-02-2010, 17:48
coldfusion1279 coldfusion1279 is offline
AKA: Mike
FRC #1279 (Cold Fusion)
coldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud of
Wow, cool looking, that's for sure.
If the traction wheels are for getting over the bump only, I would suggest re-testing without the wheels and maybe save some weight. If they are for pushing, that is a different story.
My question is, after all that machining, why didn't you weld the frame? Oxidation?
Cold Fusion's 10th Season
Unread 05-02-2010, 20:56
sgreco's Avatar
sgreco sgreco is offline
AKA: Steven Greco
FRC #2079
sgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond repute
It's worth it participating in FIRST just to see what 935's frame looks like...That is absolutely awesome...Really nice job!
pic: Team 935 kicker teaser #1 railerobotics Extra Discussion 6 23-01-2010 12:15
pic: Team 935 RaileRobotics Teaser #1 railerobotics Extra Discussion 11 17-01-2010 17:20
pic: Team 935 Chasis railerobotics Extra Discussion 24 27-01-2009 22:26
pic: Team 665 REAL Chassis, Kinda-Teaser Greg Peshek Extra Discussion 13 25-01-2008 08:14
pic: Team 1676 Chassis Teaser Spiffizzle Robot Showcase 10 28-01-2006 23:53
