Go to Post While you look at it as punishment, I look at it as a challenge. - Daniel_LaFleur [more]
Unread 05-02-2010, 13:02
rokenboker rokenboker is offline
FRC #1236
rokenboker is an unknown quantity at this point
Exclamation HELP!!!! we need help w/ compressors/pneumatics for teleop/autonomous in LABVIEW
hi, i cannot get any code to work in any type of form, one way or another. i've tried to make my own VI, use their formatting for code, nothing works!!! also i would like to state that in neither code i have vision feedback anymore.
here are some examples:
Unread 05-02-2010, 14:19
Re: HELP!!!! we need help w/ compressors/pneumatics for teleop/autonomous in LABVIE
You don't seem to have followed the Default coding conventions and that prevents your code from working.
You Open your drive motors in two different places (Begin and Teleop) and that just confuses the cRIO.
I especially like how you have the Enable Vision control sitting all by itself, unconnected to anything at all.
In your own standalone vi you are missing all the Driver Station communication, so it can never be Enabled from the Driver Station.
I think you're trying to follow last year's Basic-style in this year's Advanced-style and that won't work well.
Learn to:
  • Open all your devices in Begin.vi,
  • Close everything only in Finish.vi, and
  • Set your solenoids in Teleop.vi and Autonomous Independent.vi
We can help if you want to walk through it.
Unread 05-02-2010, 14:38
FRC #1236
yes, a helpful walkthrough would be GREAT thanks. what would be the easiest way to do that? i have
skype: rokenboker
gmail: rokenboker
or, anything thagt you would prefer, please tell me.
thanks alot!
Unread 05-02-2010, 14:58
helenajoy helenajoy is offline
FRC #2437
helenajoy is an unknown quantity at this point
Hope it's okay if I ask this here...it's related to pneumatics in LabView and how I could go about programming it.
I am sure that I do not have the same problem as the person above - we've developed original code and have seen it work. The only thing is, we've never written code for pneumatics.
I'm wondering about writing pneumatics in autonomous mode. What structure and VIs would I use to in order to include pneumatics in our autonomous?
Also - another question.
In our autonomous mode - we are planning to have our robot move and kick with pneumatics.
How can we combine these two elements? Currently, we have one sequence that controls purely the movement of the robot (going forward, back, etc.).
Is it better to program the pneumatics into that sequence? Or to create an entirely different sequence that is somehow time-linked with the first movement sequence?
Hope this makes sense! (:
Unread 05-02-2010, 15:03
FRC #1236
actually, that's kind of what i'm trying to do as well, are you using LABVIEW? if so check out some of my code, maybe we can use each other's code tohelp the both of us.
Unread 05-02-2010, 15:18
FRC #2437
Yup, we are using LabView as well. I'd offer to share our code with you, but I do not know how to upload a LabView project and all that. =/ I'll take a look at your code right now, thanks!
Unread 05-02-2010, 15:20
FRC #1236
do u have skype or gmail? that way we should be able to help each other alot faster.
Unread 05-02-2010, 15:23
FRC #2437
No, unfortunately I do not.
I only have Yahoo! messenger.
Unread 05-02-2010, 15:24
FRC #1236
rokenboker@yahoo.com
Unread 05-02-2010, 17:10
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
There is a pre-made pneumatics example included with labview. You can find it in the examples section (when you go to load up your project, you can go the lower right and click examples).
This gives you the basic code to make everything work in a nice little package. You merely need to slide it over into your actualy robot program to make it work.
You CAN load the example by itself just to prove you have all the hardware set up correctly as well.
Labview Autonomous AND Teleop Two-Face Programming 1 14-02-2009 18:33
NEED HELP WITH uncontrollable pneumatics Tds123 Pneumatics 6 11-02-2008 04:34
NEED HELP WITH WHOLE PNEUMATICS Reaper40 Pneumatics 2 17-02-2007 21:23
Need Help With General Pneumatics Ryan O Programming 7 24-01-2007 21:31
help: cannot get the picture in the labVIEW program .. (was: need help!! quickly!) liad LabView and Data Acquisition 8 18-01-2006 12:20
