Go to Post WHY ON EARTH WOULD YOU THROW AWAY THE QUADRATIC FORMULA?? - Katie_UPS [more]
Unread 03-02-2010, 21:43
caitlin2437 caitlin2437 is offline
FRC #2437 (Lancer Robotics)
caitlin2437 is an unknown quantity at this point
Send a message via Yahoo to caitlin2437
Smile Utlizing the Driver Station to Assist Autonomous Mode
In the FRC Driver Station (under the Operation tab), is a Team Station drop down menu. The options in this drop down menu include the positions such as Red 1 and Blue 2. I am assuming that this enables to driver to input the position of his or her robot?
Also, in the Autonomous Independent framework, a Get Alliance vi has been provided and used. The vi can return the team alliance and field position of the robot.
Since our team is planning on writing a different code for each field position, we would like to know if there is a way to link these two? For example, is there a way to program our autonomous so that if the driver inputs 'Red 3' in the driver station, the code that we designate 'Red 3' will run?
If that is not an option, how would you reccomend handling various codes that depend on the robot's position? Or are you all writing a general code that could work well in all positions?
Thank you! Hope I've made sense!
Unread 03-02-2010, 22:49
Re: Utlizing the Driver Station to Assist Autonomous Mode
Not quite. It actually describes the position of the team's driver station, not of the robot. During competition, it's set by the Field Management System. You likely won't be able to use the information for anything helpful.
Unread 03-02-2010, 23:05
Ah, I see.
So, it would be best to code one general autonomous sequence that could work for all three positions rather than attempting to create a seperate sequence for each position? Or are you aware of any other strategies that would allow us to include more than one autonomous sequence?
Thank you so much - that's been a huge help. Our team has been wondering about its function for quite a while. (:
Unread 03-02-2010, 23:24
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Switches or similar sensors either on the robot or on the driver station (value read during autonomous disabled and stored) are common ways to have multiple autonomous modes.
Before the match set the switches for the appropriate mode and you're all set.
You will be able to have 2^(N) modes where N is the number of switches used.
Unread 03-02-2010, 23:27
...are you aware of any other strategies that would allow us to include more than one autonomous sequence?
You can use digital or analog inputs and a multiple-position switch to tell the robot what you want it to do. Or you can put a selector on your driver station and have the robot remember its state before the match begins so it can be used during autonomous. You could even put a configuration file on the cRIO with instructions for which routine to execute.
Unread 03-02-2010, 23:29
Chris is me's Avatar
AKA: Pinecone
You can even use switches to set the number of seconds of delay you use in an autonomous with said switches. Could be useful for cooperation with alliance partners.
Unread 03-02-2010, 23:41
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
Looks like I beat Greg to this. You can also use the virtual I/O on the Dashboard, same functionality without all that messy hardware! (Note: I love the messy hardware...)
Unread 05-02-2010, 15:13
helenajoy helenajoy is offline
FRC #2437
helenajoy is an unknown quantity at this point
What the names of such switches or sensors? Or do you have any tutorials that would help me to better understand them?
Where would I get a multiple-position switch and how would I program that? Do you know where I could get some examples or tutorials to follow?
What are these switches called?
Thank you so much for all of the great advice, guys!
Unread 05-02-2010, 17:14
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
By putting the necessary code into the "Disabled" VI, you can create a small VI to use joystick buttons to increment a global variable. Use that global variable in your autonomous VI to select the routine you want to run. You can feed this back to either a custom dashboard, or use the "User Messages" VI (which feeds back to the user display in the lower left of the driverstation) so you can actively watch what you're selecting.
In this manner you don't need to build any switch, and can select the routine to run after your drivers hook everything up on the field and turn the robot on.
Remember: Disabled only means that outputs on the robot aren't set. Your code in the disabled VI is still running, so you can do work there.
Unread 13-02-2010, 13:05
Team1824 Team1824 is offline
FRC #1824
Team1824 is an unknown quantity at this point
how could you use joystick buttons to increment a global variable?
Team 1824
Driver Station for Autonomous shrimp Control System 5 03-03-2009 17:05
Driver station communication during autonomous drosophyllum Control System 1 23-02-2009 21:39
paper: Set and display your Auto-Mode using LabVIEW and the Driver Station PhilBot Extra Discussion 0 11-02-2009 12:32
Updating the Driver Station PHSRobotics FRC Control System 1 25-01-2009 19:11
Mounting the Driver Station...? 1708xMr.Roboto FRC Control System 1 15-12-2008 12:34
