Go to Post [Bring] programmers [to Championships], they may be small, quite and easy to miss while leaving for Atlanta but its hard to do anything robotic without them, I've tried. - Simon Strauss [more]
Unread 05-02-2010, 17:52
jault jault is offline
FRC #1652 (LakeView Legends)
jault is an unknown quantity at this point
Thumbs up Camera software Update 2/3/10 C/C++
There is a new update on the usfirst.org website. This update came out on February 3rd, 2010. Fixes a lot of camera issues and the lag time on the dashboard image from the camera. heres the link : http://first.wpi.edu/FRC/frccupdates.html
hope this helps.
Unread 05-02-2010, 19:47
bronxbomber92 bronxbomber92 is offline
FRC #1551 (Grapes of Wrath)
bronxbomber92 is an unknown quantity at this point
Re: Camera software Update 2/3/10 C/C++
After installing the update is anyone having problems deploying code? Its fine on the PC side in WindRiver but when I go to boot the robot the dashboard says that there is no robot code.
Unread 05-02-2010, 20:13
Spacetech's Avatar
Spacetech Spacetech is offline
Lead Programmer
FRC #0263 (Sachem Aftershock)
Spacetech is an unknown quantity at this point
Same thing happened to me. It was related to one of the DriverStationLCD class enum's. Just comment out your code that uses the class and you should be fine.
Unread 05-02-2010, 20:48
The problem was that part of the project wasn't recompiling (duh). Clean and rebuild solved my problems :-)
Unread 05-02-2010, 21:02
ideasrule's Avatar
ideasrule ideasrule is offline
FRC #0610 (Coyotes)
ideasrule is a jewel in the roughideasrule is a jewel in the roughideasrule is a jewel in the roughideasrule is a jewel in the rough
I'm supposing that there's a corresponding Java update? I'm looking at the list of updates in the updates.xml file and don't see anything...
Unread 06-02-2010, 12:09
sunit sunit is offline
FRC #1504
sunit is an unknown quantity at this point
Clean and Build did not fix the problem.
Commenting out the DriverStationLCD code did not fix the issue.
Unread 06-02-2010, 12:20
MattD's Avatar
MattD MattD is offline
AKA: Matthew Douglas
FRC #0228 (GUS Robotics)
MattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to behold
Send a message via AIM to MattD
I had an update available for the FRCSquawkSDK plugin, but after installing it I did not see any of the API changes that were present in the C++ version of the library. Am I missing something, or is a Java update to match the C++ version still pending?
GUS Robotics Team 228
2010 WPI Engineering Inspiration Award
2010 WPI Regional Champions (Thanks 230 & 20!)
2010 CT VEX Champions
2010 CT VEX Innovate Award
2009 QCC VEX Champions
2009 CT Motorola Quality Award
2007 CT J&J Sportsmanship Award
2006 CT Best Website Award
Unread 07-02-2010, 00:36
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
I'm also looking forward to said update for Java.
Unread 09-02-2010, 20:10
kevin51292 kevin51292 is offline
FRC #2753
kevin51292 is an unknown quantity at this point
Hey guys!
I installed the update a couple of days ago and it seems to have created a problem that I'm wondering if anyone on here has been able to figure out. When I declare the Axis camera instance, I tried setting the resolution of the image, but when I do that it says that my resolution (kResolution_640x480) is undeclared. I am including the updated AxisCamera.h and AxisCameraParams.h header files. Do any of you have any ideas on what I'm doing wrong? Here is what my source code looks like:
AxisCamera &camera = AxisCamera::GetInstance();
camera.WriteResolution(kResolution_640x480);
Unread 09-02-2010, 20:17
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
Originally Posted by kevin51292 View Post
Hey guys!
you aren't doing anything wrong, this is a WPILib bug. See post 3 above
Watchdog.Kill();
Unread 09-02-2010, 20:35
FRC #2753
Hmm...I'm actually not using the DriverStationLCD class. I've been using the DashboardDataSender class. Is that another problem? So if I'm not using the DriverStationLCD class is there something else that could be causing the problem?
-Kevin
Unread 09-02-2010, 20:46
MattD's Avatar
I disagree.
Try this:
camera.WriteResolution(AxisCameraParams::kResolution_640x480);
Unread 09-02-2010, 21:05
FRC #2753
Ah thank you very much!! I tried it and it worked wonderfully.
Unread 11-02-2010, 15:30
byteit101's Avatar
-Kevin
Oops! I didn't read the question all the way
Watchdog.Kill();
software update problem qpang General Forum 1 22-01-2010 19:08
password for software update? qpang General Forum 1 21-01-2010 16:10
camera software compatibilitiy Wendy Holladay NI LabVIEW 0 17-01-2010 08:57
Problems with required software update eugenebrooks Programming 0 14-02-2009 00:50
**FIRST EMAIL**/Control System Software Update Reminder Mark McLeod FIRST E-Mail Blast Archive 13 30-11-2008 21:05
