Go to Post I have also emailed Dean Kamen for more information regarding our team and its future, as I may have confused myself a bit. - ExcuseBoy [more]
Unread 05-02-2010, 19:07
Thxe Thxe is offline
FRC #2535
Thxe is an unknown quantity at this point
Re: Problems with the watchdog (I think)
Ok, here is the code. Sorry this took so long. It is based off of the Defaut Robot. The watchdog says it is not fed about 1:45 to 2:00 minutes into teleop mode.
DefaultRobot.cpp
#include <iostream.h>
#include "math.h"
//#include "Vision/AxisCamera2010.h"
#include "WPILib.h"
#include "Mecanum.cpp"
 * This is a demo program showing the use of the RobotBase class.
 * The SimpleRobot class is the base of a robot application that will automatically call your
 * Autonomous and OperatorControl methods at the right time as controlled by the switches on
 * the driver station or the field controls.
class DefaultRobot : public SimpleRobot
{			// robot drive system
	Joystick *rightStick;			// joystick 1 (arcade stick or right tank stick)
	Joystick *leftStick;			// joystick 2 (tank left stick)
	DriverStation *ds; 				// driver station object
	Mecanum *mecanum;				// Mecanum drive system
public:
	 * Constructor for this robot subclass.
	 * Create an instance of a RobotDrive with left and right motors plugged into PWM
	 * ports 1 and 2 on the first digital module.
	DefaultRobot(void)
		ds = DriverStation::GetInstance();	// create robot drive base
		rightStick = new Joystick(1);			// create the joysticks
		leftStick = new Joystick(2);
		mecanum = new Mecanum(4, 1, 2, 3, 4);
		//Update the motors at least every 100ms.
		GetWatchdog().SetExpiration(100);
	 * Drive left & right motors fo7r 2 seconds, enabled by a jumper (jumper
	 * must be in for autonomous to operate).
	void Autonomous(void)
		GetWatchdog().Feed();
		GetWatchdog().SetEnabled(false);
		//Pull triger, fire rockets
		/*	myRobot->Drive(0.5, 0.0);			// drive forwards half speed
			Wait(2000);							//    for 2 seconds						//    for 2 seconds
			myRobot->Drive(-0.5, 0.0);			// reverse robot
			Wait(2000);
			myRobot->Drive(0.0, 0.0);			// stop robot
		GetWatchdog().SetEnabled(true);
	 * Runs the motors under driver control with either tank or arcade steering selected
	 * by a jumper in DS Digin 0. Also an arm will operate based on a joystick Y-axis.
	void OperatorControl(void)
		while (true)
			mecanum->SetSpeeds(rightStick->GetX(), rightStick->GetY(), leftStick->GetX());  //It works when I comment this out.
START_ROBOT_CLASS(DefaultRobot);
Mecanum.cpp
 * Mecanum drive class
 * Team 2535
 * Theodore Dahlen
 * 2/1/2010
class Mecanum
	Victor *MotorFrontLeft;
	Victor *MotorFrontRight;
	Victor *MotorBackLeft;
	Victor *MotorBackRight;
public:
	Mecanum(UINT32 slot,
			UINT32 FrontLeft,
			UINT32 FrontRight,
			UINT32 BackLeft,
			UINT32 BackRight)
		MotorFrontLeft = new Victor(slot, FrontLeft);
		MotorFrontRight = new Victor(slot, FrontRight);
		MotorBackLeft = new Victor(slot, BackLeft);
		MotorBackRight = new Victor(slot, BackRight);
	void SetSpeeds(float X, float Y, float Twist)
		float *Wheels[4]; // 0 is FL, 1 is FR, 2 is BL, 3 is BR
		*Wheels[0] = Y + X + Twist;
		*Wheels[1] = Y - X - Twist;
		*Wheels[2] = Y - X + Twist;
		*Wheels[3] = Y + X - Twist;
		if(*Wheels[0] > 1 || *Wheels[0] < -1)
			Divide(Wheels, 0);
		else if(*Wheels[1] > 1 || *Wheels[1] < -1)
			Divide(Wheels, 1);
		else if(*Wheels[2] > 1 || *Wheels[2] < -1)
			Divide(Wheels, 2);
		else if(*Wheels[3] > 1 || *Wheels[3] < -1)
			Divide(Wheels, 3);
		else
			//YOU MAY PROBLEMS! :D
		Drive(Wheels);
	void Divide(float *Wheels[4], int Divide)
		float Divider = fabs(*Wheels[Divide]);
		*Wheels[0] = *Wheels[0] / Divider;
		*Wheels[1] = *Wheels[1] / Divider;
		*Wheels[2] = *Wheels[2] / Divider;
		*Wheels[3] = *Wheels[3] / Divider;
	void Drive(float *Wheels[4])
		MotorFrontLeft->Set(*Wheels[0]);
		MotorFrontRight->Set(*Wheels[1]);
		MotorBackLeft->Set(*Wheels[2]);
		MotorBackRight->Set(*Wheels[3]);
Last edited by Thxe : 05-02-2010 at 22:23. Reason: I deleted a function that was not used after a simplification I made. It wasn't getting called anyway.
Problem with System Watchdog JSonntag NI LabVIEW 14 20-02-2010 11:31
System: Watchdog problems dboisvert C/C++ 7 16-02-2009 02:36
System: Watchdog problems dboisvert C/C++ 1 15-02-2009 20:12
Problems with the manual of the green target (for cmu cam) Kawashima Kit & Additional Hardware 1 28-01-2007 13:31
problems mounting the camera to the 'bot with the default servo/mount set up Redneck Programming 0 16-02-2005 20:53
