Go to Post One wouldn't want to keep the red herring in hand, that gets kind of stinky. - GaryVoshol [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 05-02-2010, 22:42
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
CAN setup troubles
Just today our team decided to switch to CAN for Jag control. We ordered a Black Jaguar and the serial-can connector and I'm trying to setup some test code for CAN. I downloaded the example from FIRSTForge and loaded it into Windriver. It complained about the CANJaguar folder not being a subfolder for the example so I copied it there, and then when I tried to do a straight compile from example I got a ton of errors in "ChipObject/NiRioStatus.h". Did I skip a step in setting up the CAN code? I really need to have it working soon
Unread 06-02-2010, 02:09
simpsonboy77 simpsonboy77 is offline
AKA: Garrett Dicken
FRC #0041 (RoboWarriors)
simpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond repute
Re: CAN setup troubles
modify the include header in CANJaguar.cpp
#include "CANJaguar.h"
#include "ChipObject/NiRio.h" <-add this line
#include "ChipObject/NiRioStatus.h"
http://www.chiefdelphi.com/forums/sh...ad.php?t=80706
Please note, I do not take credit for this, I mearly copied byteit101's response that worked for me.
EDIT: For future questions, you can usually find the answer faster if you use the search function. I just put in ChipObject/NiRioStatus.h and got several hits.
2017 Shenzhen, China Regional CSA
2013 - Present MAR Control System Adviser and FTAA
2009 - Present Programming an Electrical Mentor Team 41
2007 - 2008 Team 41 Lead Programmer, Electrical
2005 - 2008 Team 41 Member
2008 NYC Regional Winner
Unread 06-02-2010, 09:22
AKA: Ian Thompson
Thank you so much. It seems to compile just fine now
Movement Troubles jaketessem FRC Control System 5 05-02-2010 16:36
Classmate troubles jaster67 Control System 4 26-01-2010 20:38
Can somebody teach me project setup in MpLab? brennerator Programming 1 09-01-2007 08:20
Bandsaw Troubles John Gutmann Technical Discussion 6 13-07-2006 02:05
Tilt Troubles Mumford 406 Programming 4 29-03-2005 22:19
