Go to Post We like to help, otherwise they put us back in our cages. - Matt Krass [more]
Unread 06-02-2010, 10:07
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: Secondary Regulator (monier)
Originally Posted by jmanela View Post
Hi -
We ran into a little bit of trouble with the secondary regulator on the robot. Currently, our pneumatics set up uses two regulators, one to create a zone at 60 psi, and another to create a zone at 30 psi. The primary regulator (60 psi zone) is working fine, but our secondary regulator (the one with the yellow ring) does not. It appears that air continues to leak out of the secondary regulator. The system will never fill up higher than what the secondary regulator is set at. This is the same set up as we have used before and it has worked before, but for some reason, it is no working at all. We have no idea why... Any suggestions?
Thanks.
Sound like you may have in installed backwards. Check and make sure.
secondary development computer a kenny03 Programming 3 25-01-2010 15:46
New team at Northern Secondary School, toronto, ON Albert Hu Starting New Teams 4 21-10-2008 15:37
pic: Secondary Pneumatic Reservoir Array Qbranch Extra Discussion 10 09-02-2008 21:19
White Oaks Secondary School Little Lee132 Chit-Chat 0 08-04-2002 21:51
Secondary Robots K. Skontrianos General Forum 1 26-03-2002 23:36
