Go to Post Robotics = my anti drug. - Queen_of_Mascot [more]
Unread 06-02-2010, 09:57
jmanela's Avatar
jmanela jmanela is offline
+1 is BIGGER than -1
AKA: Joshua Manela
FRC #2586 (Fondy Fire)
jmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to behold
Secondary Regulator (monier)
Hi -
We ran into a little bit of trouble with the secondary regulator on the robot. Currently, our pneumatics set up uses two regulators, one to create a zone at 60 psi, and another to create a zone at 30 psi. The primary regulator (60 psi zone) is working fine, but our secondary regulator (the one with the yellow ring) does not. It appears that air continues to leak out of the secondary regulator. The system will never fill up higher than what the secondary regulator is set at. This is the same set up as we have used before and it has worked before, but for some reason, it is no working at all. We have no idea why... Any suggestions?
Thanks.
||2009|| Entrepeneurship Award, QF - Traverse City | Rookie All Star, QF - Detroit | Highest Rookie Seed, Rookie All Star, QF - Michigan State Championship | Finalist - MARC ||2010|| Engineering Inspiration, Website Award, SF- Kettering | Judges Award, Website Award, SF - Detroit | Website Award, Winner, Michigan State Champ //Thank you 469 and 1918!! | Finalist - MARC ||2011|| Engineering Inspiration, Website - Kettering | Entrepreneurship, Website, Finalist - Waterford | Website - MSC
Unread 06-02-2010, 10:05
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Re: Secondary Regulator (monier)
That should work. Could it be mounted backwards(there is an arrow on the bottom indicating airflow), or one of the plugs is leaking?
Unread 06-02-2010, 10:07
IndySam's Avatar
IndySam IndySam is online now
FRC #0829 (Digital Goats)
Originally Posted by jmanela View Post
Hi -
Thanks.
Sound like you may have in installed backwards. Check and make sure.
Unread 06-02-2010, 10:11
jmanela's Avatar
AKA: Joshua Manela
The way we have it is that the arrow follows the air directional flow intended. (From the 60 to the 40). It appears that the air is actually leaking from the regulator itself. We thought it was cracked so we tried another one but the same problem.
Also, are we allowed to use two primary regulators (the fully black ones and have one of them count as a secondary regulator? Or do we have to use the same kind of secondary regulator that they gave us? I can't find anywhere in the rules that do not allow it, but I'm not sure, i might have missed something.
Unread 06-02-2010, 10:13
jmanela's Avatar
AKA: Joshua Manela
Is the arrow on the back of the regulator supposed to be in the direction of the air flow? For example, we have it so that air will go in from the start of the arrow ( ---- ) and leave from the arrow tip ( > ). Is this correct?
Unread 06-02-2010, 10:25
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
That sounds accurate.
Have you plugged both of the gauge ports on the sides if you are not using them and made sure that all fittings and plugs are properly teflon taped and tightened?
Unread 06-02-2010, 10:33
Electrical Engineer
Rookie Year: 1995
...Also, are we allowed to use two primary regulators (the fully black ones and have one of them count as a secondary regulator? ...
Joshua,
In my opinion, yes you can.
Mike
Mike Betts
As easy as 355/113...
secondary development computer a kenny03 Programming 3 25-01-2010 15:46
New team at Northern Secondary School, toronto, ON Albert Hu Starting New Teams 4 21-10-2008 15:37
pic: Secondary Pneumatic Reservoir Array Qbranch Extra Discussion 10 09-02-2008 21:19
White Oaks Secondary School Little Lee132 Chit-Chat 0 08-04-2002 21:51
Secondary Robots K. Skontrianos General Forum 1 26-03-2002 23:36
