Go to Post I wonder if Radio Shacks all over should prepare for VEX robots dropping by for spare parts just like people going to a medical clinic... - Wayne C. [more]
Unread 06-02-2010, 11:08
TPekarjr TPekarjr is offline
Rookie Year: 1111
TPekarjr is an unknown quantity at this point
Wiring The accelorometer
well funny story, at my robo shop i wired acccelorometers, turns out i wired accelorometers that were a year old and was only 2 axis o.O.... Soo inturn we located the latest accelorometer and its 3 axis.. so i did some homework trying to understand exactly how to wire it but proved to be unseccessful.
can anybody help me with wiring pwm cables to the accelorometer? thank you
Unread 06-02-2010, 11:17
Re: Wiring The accelorometer
Have you looked at the sensor manual? http://usfirst.org/roboticsprograms/...nt.aspx?id=452
Unread 06-02-2010, 11:23
Rookie Year: 1111
yes i have, and i dont quiet understand it. i mean i know the ports... but exactly how, i am a little confused at the moment
Unread 06-02-2010, 21:22
If you're using LabVIEW, there is an example showing how to use the accelerometer board with its I2C connection. I haven't looked closely at the C++ or Java environments to see what sort of accelerometer examples they have.
Originally Posted by the Sensor Manual
The I2C port is found on J2 and was designed to be easily wired to the pins on the Digital Sidecar found directly behind the NXT connector. Connect 5V to 5V, SCL to SCL, SDA to SDA, and (-) to 0V.
Are those directions exact enough, or do you need more information?
Unread 12-02-2010, 18:19
Rookie Year: 1111
i still quiet don't get it... i read the instructions but still don't understand it... i hate to be a noob but i am wiring it with pwm cable..and using all 3 axis... can someone just tell me what color on the pwm goes to what port on the accelerometer... it would be much appreciated =D
Unread 12-02-2010, 18:35
DuaneB's Avatar
DuaneB DuaneB is offline
FRC #1731
DuaneB is an unknown quantity at this point
If you're using PWM cable, you'll need to add a fourth wire to use I2C. The number of axes don't matter (for the wiring) and colors don't matter (though it may help to have black wire on 0V and red wire on 5V) - you just need to make sure the wires connect the same pins at each end. That is, the 5V pin on the accelerometer connects to the 5V pin on the digital side car, SDA to SDA, SCL to SCL, and 0V to 0V. Make sure you don't reverse one of the connectors and connect 5V to 0V or vice versa.
Unread 12-02-2010, 18:36
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Well, that's the trouble.
It's not a PWM cable; it has 4 connections.
5v, GND, SCL, and SDA
You can find the 4-pin header on the digital sidecar, right next to that female RJ-14 (modified phone jack).
However, beware that on the accelerometer, they are in a different order than on the digital sidecar.
You must solder a pigtail or header to the accelerometer.
-- Marshal Horn
Unread 17-02-2010, 21:19
LinuxArchitect LinuxArchitect is offline
AKA: George Boyce
FRC #0053 (Cow Abductors)
LinuxArchitect is a name known to allLinuxArchitect is a name known to allLinuxArchitect is a name known to allLinuxArchitect is a name known to allLinuxArchitect is a name known to allLinuxArchitect is a name known to all
The other way to wire the accelerometer might be easier if you just have the three wire pwm cables.
The SPI port is found on J4 and was setup to be easily wired to the Digital I/O on the Digital Sidecar. Although the pins can be connected to any GPIOs in any order, it is easiest to use Digital I/O 1-4. Connect 0V and 5V to the (-) and PWR pins that are just beyond Digital I/O 1, and [CK, DI, DO, CS] in order.
Looking at the 8 J4 connections, wire two pwm cables to the bottom 6. Plug the first one into the digital IO port 1 like a normal connection. Plug the second one across the signal pins of ports 2 , 3, and 4. This is slightly different from the doc quoted above which says to use the power pins located just below the port 1 pins. Not sure why it would matter.
Then go run the ADXL345 SPI Accelerometer example program and verify that you have everything wired correctly. It seemed to work for us today.
Unread 18-02-2010, 02:40
miniman's Avatar
miniman miniman is offline
FRC #0701
miniman is an unknown quantity at this point
Just a note, but keep in mind that this is a digital accelerometer and not an analog accelerometer. Years before they have given us analog ones the digital ones are a little more interesting to wire.
We are using last year's 3-axis analog accelerometer for ease of use.
--The most exciting phrase to hear in science, the one that heralds new discoveries, is not 'Eureka!' (I found it!) but 'That's funny ...' -Issac Asimov
Wiring the wireless bridge to the robot CHSboy Electrical 5 16-02-2009 23:30
Gryo, Camera, Accelorometer, Ultrasonic, and Gear Tooth Sensors in one program EHaskins Programming 8 22-05-2006 12:08
Wiring the relay for the pnumatics Placebo OCCRA 3 05-11-2002 23:04
Wiring the actuator archiver 2001 5 23-06-2002 23:11
What is the wiring for the FESTO valve? Nuts4FIRST Technical Discussion 4 12-02-2002 17:14
