Go to Post Lighten it up a little to bring it in under the 120 pound weight limit, and I think you will have something there! - dlavery [more]
Unread 06-02-2010, 11:10
Hatefulhippo Hatefulhippo is offline
FRC #2170
Hatefulhippo is an unknown quantity at this point
Driver Station Problems =/
Recently, some of the kids on my team were using the Driver station / Laptop and some how managed to get the top half of the driver profile to not show up when we log on as a driver.... anyone have some suggestions to fix this?
Unread 06-02-2010, 11:34
whatabouteve whatabouteve is offline
AKA: Dean Keithly
FRC #0245 (Adambots)
whatabouteve is an unknown quantity at this point
Re: Driver Station Problems =/
we have been having the same problem unfortunately
Unread 06-02-2010, 11:43
nitneylion452's Avatar
AKA: Joe Lee
Would it be possible for one of you to provide a picture of what your screen looks like?
Most likely, someone clicked remote dashboard. When you're using a remote dashboard, the local dashboard isn't started. Go to the setup tab and chose local dashboard and restart the driverstation.
Unread 06-02-2010, 12:05
Michaela3229
Posts: n/a
Our team had the same problem. We uninstalled the software and then used the back up flash drive to reinstall it.
Unread 06-02-2010, 13:01
FRC #2170
Is there anything short of using the restoration key to solving the dashboard issue?... I'm trying to stay away from losing the code on my classmate pc
Unread 06-02-2010, 15:03
Please don't reflash to fix your Dashboard. That's like an elephant stomping on an ant.
The Dashboard is just a program. Check the Driver Station Setup tab like Joe suggested. If it is set to "local Dashboard" and you've rebooted, then you can either install or create a new Dashboard pretty simply.
Some suggestions
Unread 06-02-2010, 16:14
GunfighterJ's Avatar
GunfighterJ GunfighterJ is offline
AKA: Joseph
FRC #2450 (RaiderBots)
GunfighterJ is an unknown quantity at this point
I don't know if you downloaded the classmate updates which are found here: http://usfirst.org/roboticsprograms/....aspx?id=10934 (Just scroll down). But the update causes the top half of the driver station to dissapear. To fix that download the missing nicyapi.dll update to get that to return and that should fix your problem.
There are 10 types of people in this world. Those that understand binary, and those that don't.
Driver Station Dashboard Problems CVassos Programming 9 16-01-2010 23:27
2010 Driver Station Netbook Driver Account and Java joshholat FRC Control System 2 10-01-2010 15:04
Driver Station dnrobotics11 Control System 2 18-02-2009 21:35
Problems with driver station gyaniv FRC Control System 2 13-02-2009 01:21
