Go to Post Jeez, I love my job! :) - dlavery [more]
Unread 06-02-2010, 12:41
Michaela3229
Posts: n/a
Crate thickness?
How thick should we make our crate? We are planning on having plywood sides with a 2X4 frame on the inside. I read the robot transportation section of the manual and there weren't any rules on wood to use except for the international shipping.
Unread 06-02-2010, 12:58
Scoutin' Master's Avatar
Scoutin' Master Scoutin' Master is offline
Read your Game Manual!
FTC #2753 (Team Overdrive)
Scoutin' Master is on a distinguished road
Re: Crate thickness?
Yes, there are no restrictions on what thickness the wood on the shipping crate must be. However, you want to make sure that you keep your weight under 400 lbs so that you won't have to pay extra for your crate.
There is a supplemental document to Section 4 of the Game Manual (found here: http://www.usfirst.org/uploadedFiles...ndations. doc) that gives some suggestions on how to build and ship your crate.
This is what it said about thickness of wood.
All crates should:
a. Be sturdily built to prevent damage to your equipment
b. Use 3/8” or 1/2” plywood or 3/8” or 1/2” Oriented Strand Board (OSB), a solid panel product of consistent quality with no laps, gaps, or voids.
Crate building cautions:
a) Medium density fiberboard (MDF) is not recommended for crate building because the material makes crate construction too heavy, and MDF can be dangerous to use if the correct safety precautions are not taken. MDF contains a substance called urea formaldehyde, which may be released from the material through cutting and sanding and cause irritation to the eyes and lungs.
b) Don’t use particleboard because it collects moisture that adds weight and may cause the crate to fall apart. Remember, your crate may be exposed to the elements when loading and unloading trucks.
Hope this helps!!
Team Overdrive FTC #2753
A big thank you to all of our sponsors and supporters!!
2006/2007: FVC #3179 - New Jersey Champions
2007/2008: FTC #74 - Ohio, Delaware, New Jersey, New York, and World Champions
2009: FRC #2753 - New Jersey Champions &
Archimedes Division Champions PARC champs, BRBR champs, & Brunswick Eruption champs
2010: FRC #2753 - NJ semifinalists, Philly semifinalists, ranked 44th in Archimedes division
2011: FTC #2753 - DE semi-finalists, NJ division finalists
Unread 06-02-2010, 16:34
Michaela3229
Posts: n/a
Thanks! that clears a lot up :)
Carpet thickness? Unaimed Assason General Forum 3 06-01-2009 23:14
Plate Thickness AndyB Technical Discussion 6 15-12-2007 08:54
Fiberglass Thickness archiver 2000 1 23-06-2002 22:53
Thickness of aluminium bars Randy_Ai Technical Discussion 1 04-02-2002 20:09
gear thickness zarb Technical Discussion 10 26-01-2002 22:07
