Go to Post Really, there are very few things in life as beautiful as a person's face when they acquire knowledge. I never tire of it. - Al Skierkiewicz [more]
Unread 06-02-2010, 12:54
ahudson ahudson is offline
FRC #3179
ahudson is infamous around these parts
2010 axis camera
Were a rookie team this year and have hardley any idea what were doing. I have configured the camera as the instructions said to do, but in the web browser on the live view screen. It says that the axis media control has not been installed. Do you have any idea how to get that?
Unread 06-02-2010, 16:13
buddyb's Avatar
buddyb buddyb is offline
FRC #1885 (ILITE)
buddyb has a spectacular aura aboutbuddyb has a spectacular aura aboutbuddyb has a spectacular aura about
Re: 2010 axis camera
You may want to try viewing the camera's stream in Internet Explorer. If that doesn't work, go in to the settings and look for how it displays the image. Select 'Java Applet' for both IE and other browsers. Doing that made it work well for us.
Good luck!
FRC - Team 1885 - Programmer.
Unread 06-02-2010, 19:36
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
If I recall, (and it's been a while since I set up the camera), that is actually downloaded from the camera and installed by your browser when you connect to it.
What browser are you using, and did it alert you that it's trying to install something?
(Someone let me know if that's off base - it's been a month since I set up the camera last).
Unread 14-02-2010, 02:03
Mintaka3's Avatar
Mintaka3 Mintaka3 is offline
Mintaka3 is an unknown quantity at this point
I suppose you don't have Java installed in your computer, go to the Java website and try to do a "test". it will tell you if you have Java or if you are not current with their updates.
2010 Axis Camera Dashboard Problems Kohala2460 General Forum 0 04-02-2010 13:34
2010 Axis Camera Dashboard Problems JesterKarrde Programming 12 04-02-2010 13:11
Java/Netbeans Camera Code for Classmate PC and Axis Camera joshholat Programming 1 23-01-2010 14:59
Axis Camera ehochstein Programming 2 21-02-2009 00:16
AXIS Camera nickmagus Programming 1 03-01-2009 20:06
