Go to Post If you think life is fair, you are sadly mistaken. - R.C. [more]
Unread 04-02-2010, 04:16
J. Stofflett's Avatar
J. Stofflett J. Stofflett is offline
FRC #0123
J. Stofflett has a spectacular aura aboutJ. Stofflett has a spectacular aura aboutJ. Stofflett has a spectacular aura about
pic: 123's vacuum
Unread 04-02-2010, 04:17
craigboez's Avatar
craigboez craigboez is offline
Mechanical Engineer
AKA: Craig Boezwinkle
FRC #2811 (StormBots)
craigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nice
Re: pic: 123's vacuum
Are you powering your vacuum/impeller assembly 1:1 with an FP motor?
Unread 04-02-2010, 20:04
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
As far as I can tell from the picture, it looks to be a centrifugal impeller system. The FP is just being used to spin a little metal disk like the one you'd find in your shop vac. It's a low torque, high speed application that's perfect for the FP. 1771 and 190 built similar systems in 2008.
Unread 04-02-2010, 20:13
FRC #0123
Yes it is 1:1 drive using FP works great
Unread 04-02-2010, 22:00
DonRotolo's Avatar
Back to humble
FRC #0832
Um, don't take this the wrong way, but that looks like it really sucks. I mean that in a good way.
Unread 06-02-2010, 13:30
Numbers's Avatar
Numbers Numbers is offline
Cyberdemon
FRC #3238 (Team Red)
Numbers is an unknown quantity at this point
Send a message via MSN to Numbers
What are the suction-cup type devices you're using to make the seal with the ball on the sucker?
Vacuum scottydoh General Forum 21 10-02-2008 23:59
pic: Vacuum System Branden Ghena Extra Discussion 14 20-12-2007 08:10
pic: Dancing the Vacuum Fantastic Mark McLeod Extra Discussion 13 05-03-2007 19:14
pic: Vacuum Diagram Andrew Morris Extra Discussion 1 26-01-2007 11:45
Vacuum NoRemorse Rules/Strategy 25 22-01-2004 12:34
