Go to Post Hello... I need one order of Thunderchicken, extra crispy. Yes, I would like fries with that. OK... go ahead and super-size it. What, only $2.17!? Sweet. - Andy Baker [more]
Unread 27-01-2010, 17:58
guitarbonham guitarbonham is offline
FRC #3023
guitarbonham is an unknown quantity at this point
Connecting Solenoid to CRIO
I know where the dual valve solenoid is supposed to be plugged into the solenoid breakout, but I can't find anything in the KOP to connect the wire to the two prongs on the solenoid breakout. does anyone have any recommendations on how best to do this?
What guage wire is required to connect it?
thanks!
Unread 27-01-2010, 19:13
Dr. J-Hoganski Dr. J-Hoganski is offline
FRC #1027
Dr. J-Hoganski is an unknown quantity at this point
Re: Connecting Solenoid to CRIO
its a little tiny double toothed piece that wires go in and its 12 or 14 awg
Unread 27-01-2010, 19:51
FRC #3023
I couldn't find it. Does it come in the KOP? I only found wires that had a female 2 pin head, but were female on both ends and were a very small guage.
Unread 27-01-2010, 20:05
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
I told our Electrical lead that we had to put in the same cord today, and what he did was take a 3 pin and cut it to make it a 2 pin... So the best I can give you is improvise?
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 27-01-2010, 21:39
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
On the SMC solenoids (which is what we are using) the same 2 pocket PWM connector that you connect to the solenoid breakout can be inserted into the solenoid itself and hot glued into place.
If you do not have a 2 pocket pwm style connector, you can easily cut a 3 pocket one down with sidecutters, dremel, or a bench grinder.
Unread 27-01-2010, 22:46
The double ended female 2-pin cables you found are intended for 2-pin use.
This includes solenoids and the Robot Status Light (RSL).
You cut them in half to get two connectors. So take half and wire it to your solenoid wires, then the female end just plugs into the Solenoid Breakout.
Unread 06-02-2010, 17:10
kws4000's Avatar
kws4000 kws4000 is offline
Team Mentor - Programming
AKA: Krazy Karl
FRC #2405 (Divided by Zero)
kws4000 is a jewel in the roughkws4000 is a jewel in the roughkws4000 is a jewel in the roughkws4000 is a jewel in the rough
Question Re: Connecting Solenoid to CRIO
I'm more of a visual learner, could you please provide a diagram on exactly how the new 2010 festo valves connect? I'm fairly sure that the leads have to be combined on both solenoids to get them to move in unison, but please don't quote me.
Thanks
connecting to Crio using windriver Tds123 Programming 1 27-01-2010 13:21
Trouble connecting to cRIO? darty Programming 17 31-01-2009 16:15
Connecting to the cRIO lingomaniac88 Programming 1 30-01-2009 10:58
Connecting Axis camera to cRIO laultima FRC Control System 20 21-01-2009 16:56
Connecting Power Distribution block to cRio Paul Rodi Electrical 2 05-01-2009 18:20
