Go to Post FRC isn't for every school; it takes a lot of drive just to fundraise every year. It is a premium program that requires a premium about of effort to sustain and be successful. And man is it fun to do. - JesseK [more]
Unread 06-02-2010, 17:36
robotic321's Avatar
robotic321 robotic321 is offline
FRC #1793
robotic321 is an unknown quantity at this point
Arrow Issue with Solenoid Timing. VI Included.
Hi. I made my own SubVI to shutoff a solenoid after X amount of time, problem is, the robot stops for X amount of time. What i want to do is to set a solenoid to on/ off if its off already, but if its on, wait 0.5 secs and then shut it off for 1.5 secs. Can anyone help me achieve this without turning off the robot for X amount of time?
Unread 06-02-2010, 18:39
Re: Issue with Solenoid Timing. VI Included.
Your VI looks reasonable to me. How are you calling it?
Unread 08-02-2010, 12:11
robotic321's Avatar
FRC #1793
Question Re: Issue with Solenoid Timing. VI Included.
Yes. Should i post the teleop vi too since it is where my VI is?
Unread 11-02-2010, 14:47
robotic321's Avatar
FRC #1793
Bump..Please assist in this matter. 1793 will greatly aprreciate it.
1793 FTW
Unread 11-02-2010, 15:17
OSU_Springer OSU_Springer is offline
Babcock & Wilcox - Engineer
AKA: Bill Springer
FRC #0677 (Murphy's Outlaws)
OSU_Springer is an unknown quantity at this point
I'm guessing, since you have your timed sequence built within your teleop, what is happening is that your teleop VI gets to the timed sequence and executes that loop. The problem is, while the loop is executing, the system never runs another iteration until that loop is done. That being said, what you need to do is move the timed sequence outside of the teleop vi. You will have to pull information from either the periodic tasks from main.vi, or have some way to pull time data from the cRio and compare the start time of the solenoid to the current time, and based on that have the solenoid go false if the time is greater than the period you're looking for.
Hope this is helpful.
Unread 11-02-2010, 16:19
Ziaholic's Avatar
Ziaholic Ziaholic is offline
Elec/SW Mentor
AKA: Marc
FRC #1164 (Project NEO)
Ziaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the rough
I'm at work and don't have access to your VI.
Does your VI have either a shift-register or a feedback node? In order to perform tasks that take longer than a standard loop-time (20 msec), you have to insert loop-to-loop memory. Typically this is done with a shift register.
When you enter the first state, you capture the current time, add an offset (your 0.5 or 1.5 seconds become 500 or 1500 msec) and store that in the shift register. Then, every time through the loop, you look at the current time, compare it to the stored/offset time, and once you exceed the timer, you exit the state and enter into the new state on the next go-round.
I posted a somewhat-related example in another thread ... (clicky) ... I have a couple diagrams in post #11 that show a 30 msec example ... and there are other posts above and below mine that also have some good advice when performing timed tasks.
G/L.
There are 10 types of people. Those who understand binary, and those that do not.
Team #1164 - Project NEO Robotics
solenoid with compressor vi ElanaC NI LabVIEW 42 29-12-2010 13:38
Solenoid Programming Issue. Dr. Manhattan Pneumatics 2 10-02-2009 17:42
Issue with Color Tracking Example (C/C++) and with Counters, Encoders, and Ultrasonic BradAMiller Programming 3 19-01-2009 21:24
Timing with the Driver Station Zorkinian Programming 6 10-01-2009 09:42
Playbook now included with Team 340 database archiver 2001 0 24-06-2002 01:33
