Go to Post More to the point, stop worrying about whether your "Atlanta bot" got screwed over or whatever. Worry about whether you've got an "Atlanta team." - RebelWithARobot [more]
Unread 06-02-2010, 18:19
closed-loop torque (current) wheel control for mecanum
Has anyone tried using closed-loop torque (current) control for a mecanum or holonomic bot, instead of closed-loop speed or voltage control?
Unread 06-02-2010, 19:38
AKA: Dr. Brooks
no team (WRRF)
Re: closed-loop torque (current) wheel control for mecanum
We used closed loop current control last year to prevent wheel slip, as we did not design in wheel counters and a "free wheel" with a wheel counter from the start. You had to use the Jaguars for this, the Victor pulse rate is too slow to get a reliable average current measurement.
Eugene
Unread 06-02-2010, 20:14
I'm not sure I understand how closed-loop current control prevents the wheels from slipping. Could you elaborate a bit?
Unread 07-02-2010, 00:54
AKA: Dr. Brooks
no team (WRRF)
The torque is proportional to the current, limit the torque to just below the torque that causes wheel slip, and your wheels never break traction. It was a good patch given the lack of wheel counters (including a free wheel) in that it only required current sensors and some software.
There are rubs:
As the speed of the robot runs up, some of the torque (measured current) is tied up in drive train friction and because of this you lose a portion of the torque that you would like applied to the wheels.
The best performance is obtained with just a little slip and you can best obtain this by using wheel counters (including a free wheel with a counter).
Eugene
Radio Packet loss + closed loop control system = lunging robot Dave K. Control System 5 20-02-2007 06:09
Torque vs. Current in small CIM motors robotguru1717 Electrical 2 08-01-2007 17:09
PID control loops - closed loop feedback KenWittlief Technical Discussion 56 26-04-2004 21:27
How Can You Make A Closed Loop System???? GRR_340 Pneumatics 6 21-03-2002 12:27
Sensible Torque/Speed/Current Graphs l1jmx Rules/Strategy 2 10-01-2002 09:47
