Re: Battery problem
If you want to bolt through the battery to the robot, I would suggest you find another securing mechanism.
There is no one bolt that goes with the battery, any bolt and nut that will hold the connector to the terminal will work. Last edited by ATannahill : 06-02-2010 at 20:24. |
Re: Battery problem
Thank you but i mean for the terminals, the pos and neg, becasue we cant find ours, so we need to purchase some
Re: Battery problem
Like rtfgnow said, any bolt that fits the hole on the terminal will work. If I can remember a 8-32 will fit.
Re: Battery problem
Yes, just measure the size of the hole in the battery terminal and buy some at the hardware store (or lowes or home depot or even wal mart). Just keep in mind that you can't get screws (or bolts) that are too long, you really don't want them to stick out too much. Maybe 1/2" is about right, maybe 5/8? Dunno. Also, you need nuts of the same size, plus washers (both plain and star-type locking!).
Good luck |
Re: Battery problem
Pretty sure they use 5mm metric, but #10-32 would also work. It's a skosh under 1/4" diameter.
Re: Battery problem
This is a violation of <R60>. Hard to get caught doing it, but knowingly violating a rule is not very gracious. (And unknowingly is not very professional)
Your call. |
#7
Re: Battery problem
I defer to your genius. |
| [FTC]: 0.0v on Ext Battery Problem | JohnFogarty | FIRST Tech Challenge | 10 | 29-01-2010 11:40 |
| Problem with the battery charger | Lightposter | Electrical | 4 | 19-01-2006 10:39 |
| Urgent!!! Problem concerning Backup battery and autonomous. | Code\\Pilot | Programming | 3 | 26-02-2004 16:44 |
| Battery Charger for long term battery care | DougHogg | Kit & Additional Hardware | 0 | 08-02-2003 15:25 |
| Battery Problem | mnkysp6353 | Electrical | 3 | 21-02-2002 07:42 |
