Go to Post This is what happens when Engineers try to design a sport. - Jim Zondag [more]
Unread 06-02-2010, 14:56
captainking's Avatar
captainking captainking is offline
Level 85 Programmer
FRC #0168 (MIB)
captainking is an unknown quantity at this point
Driver Station not working on Developer account
So we're having some issues with the driver station, we are using the classmate laptop that FIRST provided. When we load the code, the driver station on the developer's account says that it sees the robot (the robot light turns green), however it keeps saying that there's no communication. When we switch to the Driver account, the communication light turns green and says the code's loaded. On a side note, it keeps saying "watchdog not fed" no matter what the code is and it hasn't had this problem since the driver station problem started.
Unread 06-02-2010, 22:30
Re: Driver Station not working on Developer account
You used the phrase "switch to the Driver account", which makes me wonder if you're trying to log on as both Driver and Developer simultaneously, switching between them without logging off.
Don't do that.
If you have the Driver Station application running in the Driver account, it won't run properly in the Developer account at the same time. When you want to use the Developer account, make sure you log off the Driver account first. To do that, click the "Exit" button on the Setup tab.
Unread 07-02-2010, 21:02
Dustin Shadbolt's Avatar
Dustin Shadbolt Dustin Shadbolt is offline
In a server room somewhere...
AKA: Dustin Shadbolt
FRC #1555 (Team PULSE)
Dustin Shadbolt is on a distinguished road
I do believe the issue with the watchdog is an error in the actual drive station program stuff. I read somewhere they will be releasing a patch soon. ~Dustin
Unread 07-02-2010, 22:01
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Watchdog not fed is a different issue.
The current bug with the driverstation is "Watchdog Expiration: user xx system xx" or something close to that.
I think Alan nailed the Issue on the head.
Unread 07-02-2010, 23:24
Rapt0r9's Avatar
Rapt0r9 Rapt0r9 is offline
AKA: Tyler
FRC #0747 (Flight Crew)
Rapt0r9 will become famous soon enoughRapt0r9 will become famous soon enough
Did you update the driver station? You should see a compass in the lower right hand corner if it is the current version.
BS Information Technology - NJIT (2009 - )
Team 869 (2004 - 2008, 2011 -), Team 1811 (2010), Team 869 (2009), Team 613 (2009 - 2010)
"Nothing in this life worth having comes easy."
Driver Station not working on Developer account captainking FRC Control System 1 06-02-2010 17:23
How do you run Driver Station on the Developer Account? Navirahman NI LabVIEW 7 30-01-2010 20:25
Log out of Developer to use DRIVER STATION? JimC2550 NI LabVIEW 3 17-01-2010 22:01
2010 Driver Station Netbook Driver Account and Java joshholat FRC Control System 2 10-01-2010 15:04
Driver Station Not Updating elbuo FRC Control System 8 13-01-2009 18:39
