Go to Post WHAT!?!?!? YOU DON'T DEVOTE YOUR LIFE TO APPLE!?!?!?!? ;) :p - Joe Matt [more]
Unread 06-02-2010, 22:47
CapnKernel CapnKernel is offline
Parse Error on line: Unknown
FRC #1515 (MorTorq)
CapnKernel has a spectacular aura aboutCapnKernel has a spectacular aura about
Using cRIO slot 8 as a digital module?
Is it possible to use this slot as a digital module? Java doesn't seem to like it, however, is it competition legal/possible?
Unread 06-02-2010, 22:57
Re: Using cRIO slot 8 as a digital module?
The slots are defined by the FPGA image. They won't work any other way.
You must have an analog module in slot 1 <R66>. You may have a second analog module in slot 2.
You must have a digital module in slot 4 <r59>. You may have a second digital module in slot 6.
You may have pneumatic modules in slot 7 or 8.
Ribbon Cable between Digital Module and Sidecar? manderson5192 Control System 3 29-01-2010 09:42
Changing Crio Digital Sidecar input slot from slot 4 to 5 Trevor_Decker Java 9 28-01-2010 12:29
Open motor reference on Slot 6 DIO Module trilogy2826 NI LabVIEW 2 27-01-2009 08:42
Using another module to program the Vex CyberTroniX FIRST Tech Challenge 3 26-09-2005 13:13
using SPIKE relay module with Fisher Price motors 1574aviad Motors 4 27-01-2005 01:49
