Go to Post Just a modest request for folks NOT to put 3000-pixel-wide pictures inline in the forum. A link to the big picture works just as well while keeping the text readable. Thanks. - Rick TYler [more]
Unread 06-02-2010, 19:57
Faldor Faldor is offline
New Guy!
AKA: Jake Sinclair
Team Role: Photography
Faldor is an unknown quantity at this point
Send a message via MSN to Faldor
Battery problem
Hi, i'm having some trouble finding the bolt type (thread size, length, width) for the battery, it is the Enersys NP18-12 Rookie battery, thanks.
http://uguf.proboards.com/
Unread 06-02-2010, 20:18
ATannahill ATannahill is offline
AKA: Alex Tannahill
Re: Battery problem
If you want to bolt through the battery to the robot, I would suggest you find another securing mechanism.
There is no one bolt that goes with the battery, any bolt and nut that will hold the connector to the terminal will work.
- Arizona North
Unread 06-02-2010, 20:44
New Guy!
AKA: Jake Sinclair
Re: Battery problem
Thank you but i mean for the terminals, the pos and neg, becasue we cant find ours, so we need to purchase some
Unread 06-02-2010, 20:46
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Re: Battery problem
Like rtfgnow said, any bolt that fits the hole on the terminal will work. If I can remember a 8-32 will fit.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 06-02-2010, 22:23
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Battery problem
Yes, just measure the size of the hole in the battery terminal and buy some at the hardware store (or lowes or home depot or even wal mart). Just keep in mind that you can't get screws (or bolts) that are too long, you really don't want them to stick out too much. Maybe 1/2" is about right, maybe 5/8? Dunno. Also, you need nuts of the same size, plus washers (both plain and star-type locking!).
Good luck
Unread 06-02-2010, 22:25
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Battery problem
Pretty sure they use 5mm metric, but #10-32 would also work. It's a skosh under 1/4" diameter.
Unread 06-02-2010, 23:12
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Battery problem
Originally Posted by Cascade View Post
We usually clean out the battery post holes to 1/4 inch.
This is a violation of <R60>. Hard to get caught doing it, but knowingly violating a rule is not very gracious. (And unknowingly is not very professional)
Your call.
Unread 07-02-2010, 10:41
Re: Battery problem
Jake,
The hardware was packed inside the box that the battery shipped in. I highly recommend placing a star washer between the battery terminal and wire terminal when make the connection. This small addition prevents the two terminals from moving and that it turn prevents the hardware from becoming loose which in turn raises the series resistance of the connection.
Unread 07-02-2010, 14:05
Cascade Cascade is offline
Intermittent Mentor
Cascade is a splendid one to beholdCascade is a splendid one to beholdCascade is a splendid one to beholdCascade is a splendid one to beholdCascade is a splendid one to beholdCascade is a splendid one to beholdCascade is a splendid one to behold
Re: Battery problem
Your call.
I stand corrected: you are right. To say, however, "And unknowingly is not very professional" is arrogant considering how much rules are discussed, misunderstood,and debated every year, including on this forum and the official FIRST Q&A. There will be further misunderstanding again in the pits this year as teams melt down for knowingly or unknowingly misunderstanding or missing a rule.
I defer to your genius.
"Never quit, never give up, never say die!"
Unread 09-02-2010, 00:22
New Guy!
AKA: Jake Sinclair
Re: Battery problem
Thanks all who have helped, you really have.
Jake,
And Al, becasue of issuse with mailing we didnt get our battery, we had to order the same one from australia, so no parts were included. But thanks for your help anyway.
Unread 09-02-2010, 07:38
Re: Battery problem
Anytime!
[FTC]: 0.0v on Ext Battery Problem JohnFogarty FIRST Tech Challenge 10 29-01-2010 11:40
Problem with the battery charger Lightposter Electrical 4 19-01-2006 10:39
Urgent!!! Problem concerning Backup battery and autonomous. Code\\Pilot Programming 3 26-02-2004 16:44
Battery Charger for long term battery care DougHogg Kit & Additional Hardware 0 08-02-2003 15:25
Battery Problem mnkysp6353 Electrical 3 21-02-2002 07:42
