Go to Post robots like to give you troubles... its like they have a mind of their own. - hayleybayley217 [more]
Unread 06-02-2010, 21:29
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
Team 1592 Final Kicker design
Our final kicker design on our protobot:
http://www.youtube.com/frcteam1592#p/a/u/0/Sfc7erbtuoE
1592(Student and Mentor) 2007-Present
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
Unread 06-02-2010, 21:31
Meredith Novak's Avatar
Meredith Novak Meredith Novak is offline
no team (Arkansas FIRST)
Meredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond repute
Re: Team 1592 Final Kicker design
Cams!!!! I love cam systems!
Unread 06-02-2010, 21:32
V_Chip's Avatar
V_Chip V_Chip is offline
Back in action.
AKA: Victor
FRC #0175 (Buzz Robotics)
V_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud of
Clean and effective.
Estimated Range?
Unread 06-02-2010, 21:33
Techgirl675's Avatar
Techgirl675 Techgirl675 is offline
FRC #0675
Techgirl675 will become famous soon enough
Send a message via AIM to Techgirl675
ooohhh very nice, how far is it kicking?
"You're doin it wrong!"
http://techhighteam675.com/
dodar's Avatar
between 20-25 feet and around 3-6 feet in height
Unread 06-02-2010, 21:37
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Beautiful! thats one of the designs we though of but didn't think of how to make it so well
Can you reduce the kicking distance somehow?
Unread 06-02-2010, 21:38
sportzkrazzy's Avatar
sportzkrazzy sportzkrazzy is offline
AKA: Zac
FRC #1592 (Bionic tigers and 801 Horse power)
sportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant future
Send a message via AIM to sportzkrazzy
Easily clears 2 bumps.
Unread 06-02-2010, 21:40
dodar's Avatar
Yes, we have lighter springs to do so but if we change one thing on our design, little fact being kept secret , this design can be made for scoring from mid-range, but if also left in this configuration it can maybe score from the defensive position
Unread 06-02-2010, 21:41
AKA: Zac
Yeah we can do it manually by switching spings but we also have something to change the tension
Unread 06-02-2010, 22:10
GaryVoshol's Avatar
Cogito ergo arbitro
Is it timed correctly? I counted 5 shots in the 10 second video.
Originally Posted by <G30>
a. BALL Interaction Volume – Solely for the purposes of interacting with a BALL, MECHANISMS that are below the BUMPER may extend up to the BUMPER PERIMETER, for a period not exceeding two seconds. After returning inside the FRAMER PERIMETER, such MECHANISMS are not permitted to re-extend beyond the FRAME PERIMETER for at least two seconds.
If your kicker is not retracting almost instantaneously, you will be extending again in less than 2 seconds. I'm sure it won't be a big problem to slow the cycle time down to 2.5 or 3 seconds. Is there a way to fire it at will, rather than regularly and continuously?
If your kicker doesn't go beyond the FRAME PERIMETER at all, please disregard the concerns in this post.
(since 2004)
Unread 06-02-2010, 22:12
dodar's Avatar
Yes we immediately thought of this rule when designing our kicker and yes it does stay inside our frame perimeter so we can multi-fire but most likely will never have the chance to in a real game environment, but its always cool to see
Unread 06-02-2010, 22:19
AKA: Zac
Yeah we are putting a switch on it so we can stop it in the cocked position
Unread 06-02-2010, 22:34
dodar's Avatar
One thing to point out about the video is that not all the balls are filled to the right size, some arent pumped up enough, but they are mostly good.
The last ball shot was the worst, hence why it didnt make it over the burm
Unread 06-02-2010, 23:12
BradMello's Avatar
BradMello BradMello is offline
Broken Arrow
FRC #0078 (Rhode Rage & AIR Strike)
Team Role: Driver
BradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant future
Send a message via AIM to BradMello
Simple, clean and effective...I like it
Unread 07-02-2010, 00:08
andy174drive's Avatar
andy174drive andy174drive is offline
FRC Team 0174
AKA: Andy Dodd
FRC #0174 (Arctic Warriors)
Team Role: Driver
andy174drive is an unknown quantity at this point
Send a message via AIM to andy174drive
I love it guys! We're using the same idea with springs rather than surgical tubing or bungee cords. I love the cam idea, we couldn't find a good enough way to apply a cam shaft so we have pneumatic load cylinder and a separate firing one. Congrats on the great design!
Kicker Design Challenge Guopeter Technical Discussion 11 15-02-2010 14:50
Team 1592 Kicker dodar Robot Showcase 0 30-01-2010 22:48
842 Final Kicker Desgin kE7JLM General Forum 34 27-01-2010 13:41
571- Final Kicker Jones571 Robot Showcase 6 27-01-2010 06:50
Spring Powered Kicker Design Jeeman Technical Discussion 1 19-01-2010 08:08
