Relay
Whenever we try to activate our Relay with a button it tells me "Module in Slot 2 is not a Solenoid Module. Can someone please give a sample relay code? I would be very thankful.
Re: Relay
Can anyone confirm this? -RC |
Re: Relay
Well we had it in Slot 8 and yes it is supposed to be there BUT whenever I try to run the button for the Spike Relay the output is telling me "Module in slot 2 is not a solenoid. Isn't that strange?
Re: Relay
Yes it is strange, but then again I'm not a programmer. Someone with some programming skills should chime in for your problem soon.
-RC |
Re: Relay
If you're trying to control a Spike, you should be using the Relay class, not the Solenoid class. Note that the Spike should be connected to the relay ports on the Digital Sidecar, not the Solenoid breakout board. |
Re: Relay
also you could Creating it wrong...
This Correct Solenoid S1 = Solenoid(1); //Port 1 / Module 8 This Correct Solenoid S1 = Solenoid(8,1); //Port 1 / Module 8 Incorrect because slot 2 is not valid for the solenoid module Solenoid S1 = Solenoid(2,1); //Port 1 / Module 2 |
| C++ Relay Code? | Happyisgood | C/C++ | 10 | 16-07-2009 14:54 |
| Programming a relay in C++ | Kage | C/C++ | 2 | 10-01-2009 17:51 |
| Relay Commands | Matt Krass | Programming | 6 | 18-02-2006 23:03 |
| Relay Assignments | MulletFish | Programming | 9 | 27-01-2005 14:15 |
