Go to Post It's The Hunger Games and those lucky teams are Prim. - Gregor [more]
Unread 06-02-2010, 23:20
Robopanda6 Robopanda6 is offline
FRC #2477
Robopanda6 is an unknown quantity at this point
Relay
Whenever we try to activate our Relay with a button it tells me "Module in Slot 2 is not a Solenoid Module. Can someone please give a sample relay code? I would be very thankful.
"They say the struggle only sweetens the success"...I guess that's why I stayed in Robotics.
Unread 06-02-2010, 23:50
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: Relay
Well do you have the solenoid breakout/module in slot 2? I do believe its suppose to be in Slot 8.
Can anyone confirm this?
-RC
R.C.
MadTown Robotics Team 1323
Unread 07-02-2010, 00:04
FRC #2477
Re: Relay
Well we had it in Slot 8 and yes it is supposed to be there BUT whenever I try to run the button for the Spike Relay the output is telling me "Module in slot 2 is not a solenoid. Isn't that strange?
Unread 07-02-2010, 00:10
R.C.'s Avatar
Re: Relay
Yes it is strange, but then again I'm not a programmer. Someone with some programming skills should chime in for your problem soon.
-RC
R.C.
Unread 07-02-2010, 00:11
MattD's Avatar
MattD MattD is offline
AKA: Matthew Douglas
FRC #0228 (GUS Robotics)
MattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to behold
Send a message via AIM to MattD
Re: Relay
-RC
The solenoid module can be used in slot 7 or slot 8. The default is slot 8.
If you're trying to control a Spike, you should be using the Relay class, not the Solenoid class. Note that the Spike should be connected to the relay ports on the Digital Sidecar, not the Solenoid breakout board.
GUS Robotics Team 228
2010 WPI Engineering Inspiration Award
2010 WPI Regional Champions (Thanks 230 & 20!)
2010 CT VEX Champions
2010 CT VEX Innovate Award
2009 QCC VEX Champions
2009 CT Motorola Quality Award
2007 CT J&J Sportsmanship Award
2006 CT Best Website Award
Unread 07-02-2010, 01:08
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Re: Relay
also you could Creating it wrong...
This Correct
Solenoid S1 = Solenoid(1); //Port 1 / Module 8
This Correct
Solenoid S1 = Solenoid(8,1); //Port 1 / Module 8
Incorrect because slot 2 is not valid for the solenoid module
Solenoid S1 = Solenoid(2,1); //Port 1 / Module 2
C++ Relay Code? Happyisgood C/C++ 10 16-07-2009 14:54
Programming a relay in C++ Kage C/C++ 2 10-01-2009 17:51
Relay Commands Matt Krass Programming 6 18-02-2006 23:03
Relay Assignments MulletFish Programming 9 27-01-2005 14:15
