Go to Post Each team is different, your mileage may vary. What works for your team does NOT necessarily mean it will work for others. - Andrew Schreiber [more]
Unread 07-02-2010, 00:02
Re: Encoder Trouble
Originally Posted by Kahn! View Post
I'm getting CounterIndex set as Invalid. When is that set and what can I do to fix this?
It's set in the 1x or 2x Decoding Type case of the Encoder Open vi. It remains unset (i.e. Invalid) in the 4x case, because a Counter is used in the implementation only for 1x or 2x decoding.
Why do you think it needs to be fixed?
Lab View Update 3.0 encoder trouble Funnyman2003 Programming 2 03-02-2009 08:52
Screwing Encoder into Encoder Mount? Adrien Electrical 3 25-01-2009 18:14
KOP Gear Tooth Encoder Trouble Sykan Programming 11 16-02-2008 20:53
Inventor software trouble/ FIRST Base trouble nasa-senpai General Forum 2 24-01-2007 09:15
encoder.c Gary Bonner Programming 2 14-01-2005 13:41
