Go to Post Thankfully, no magic smoke was released during the making of these photos. - SteveGarward [more]
Unread 06-02-2010, 11:49
bubushkinator bubushkinator is offline
FRC #2202
bubushkinator is an unknown quantity at this point
Xbox 360 Controller Rumble
We are coding on Windriver and I was just wondering if anyone figured out how to send force feedback to an Xbox 360 controller to make it rumble. Is it a simple digital output, is there something in the joystick class, or is there anything with the driver station?
Thanks for your reply.
Unread 06-02-2010, 22:07
Re: Xbox 360 Controller Rumble
There's no built-in way I know of in the robot joystick data for information to flow back to the controller. The best option I've heard of is to use the Dashboard to talk to the game controller via DirectInput.
Unread 06-02-2010, 23:44
keehun's Avatar
keehun keehun is offline
Team Captain
AKA: Keehun Nam
FRC #2502 (EP Robotics)
keehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond repute
Send a message via AIM to keehun
That would actually be very helpful. Like it can tell the operator if the ball is in possession with the ball-handling mechanism or it could tell the driver the robot's aligned with the target and is ready to shoot, etc. I should try that out.
For by grace you have been saved through faith, and that not of yourselves; it is the gift of God, not of works, lest anyone should boast. -- Ephesians 2:8-9
2010: Quarter Finalist (MN 10,000 Lakes)
2010: Website Award (MN 10,000 Lakes)
2009: Quarter Finalist (MN 10,000 Lakes)
2009: GM Industrial Award (MN 10,000 Lakes)
Unread 07-02-2010, 00:00
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Is there any chance someone who figured out the XBOX controller post some code? It would really help a lot of teams out there.
Thanks,
-RC
R.C.
MadTown Robotics Team 1323
Unread 07-02-2010, 00:30
MattD's Avatar
MattD MattD is offline
AKA: Matthew Douglas
FRC #0228 (GUS Robotics)
MattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to behold
Send a message via AIM to MattD
I've been thinking about doing something like this with our joystick. The best way to go about it, as mentioned, would be to write a custom dashboard that communicates with the joystick using DirectInput.
The problem I see is that force feedback requires acquiring the input device in an exclusive cooperative level. I'm not too familiar with DirectInput, so I'm concerned that doing this would prevent the DriverStation process from reading input. Hopefully, the DS opens it in the non-exclusive cooperative level. Maybe someone more familiar with that could chime in on this...
Regardless, I'll probably be playing around with this over the next week or two.
GUS Robotics Team 228
2010 WPI Engineering Inspiration Award
2010 WPI Regional Champions (Thanks 230 & 20!)
2010 CT VEX Champions
2010 CT VEX Innovate Award
2009 QCC VEX Champions
2009 CT Motorola Quality Award
2007 CT J&J Sportsmanship Award
2006 CT Best Website Award
Unread 09-02-2010, 15:05
DjMaddius's Avatar
DjMaddius DjMaddius is offline
AKA: Matt Smith
FRC #2620 (Southgate Titans)
DjMaddius is an unknown quantity at this point
You have to use the Xinput library from microsoft to control the 360 controllers.
Do some research and you should find it no problem. Id give you the code i stewed up the other day but i dont have my laptop with me ATM and its on that.
Ill see if i can upload it tonight when i get home.
Anyways, if you check the microsoft website & do some research form google and you should be able to get it easy. (There are a few simple ways to control the motors. Very simple ways.)
But there is one hitch, the left motor (or possibly right. Forgot which exact one) seems to rumble a lot harder than the other one. One is soft and one is hard. You can use this to your advantage if you decide to have multiple rumble modes.
Labview 8.6: Xbox 360 wired controller Questions Lucario231 NI LabVIEW 3 20-01-2010 18:03
Xbox 360 controller LabView CJBrick General Forum 12 17-12-2008 13:58
xbox 360 controller installation kuelin Technical Discussion 17 07-01-2008 19:43
Chicklet with MS XBOX 360 controller 354.FIRST Control System 2 19-04-2007 16:29
chicklet USB/xbox 360 controller spsteam1512 Control System 1 10-01-2007 23:14
