Go to Post I believe youth is contagious. I want to catch as much as I can! - Al Skierkiewicz [more]
Unread 07-02-2010, 00:33
stevethetinker stevethetinker is offline
FRC #1288 (RAVEN)
stevethetinker is an unknown quantity at this point
trouble undeploying default or downloaded code
I need to do some debugging and I am unable to get the downloaded code, whether default or mine, to undeploy. I get the following message when I try:
Unable to delete the UserProgram from the robot
The odd part is this used to work (famous last words). I had some trouble from downloading (FIRST->Download) a program that did not clean up its tasks and I had to re-image the cRIO. Since then I've had odd problems.
I found some posts on this from last year but they are not helpful. Has anyone encountered this problem this year?
Unread 07-02-2010, 11:54
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: trouble undeploying default or downloaded code
Deploying a new program should overwrite the old one. Thus you should never need to undeploy code.
Kettering Motorsports
Unread 07-02-2010, 17:40
FRC #1288 (RAVEN)
In order to debug a kernel task, the instructions say to undeploy the existing code because somehow it interferes with the debugger. I need to run the debugger. Ergo, I need to undeploy the downloaded code.
Unread 09-02-2010, 15:01
FRC #1288 (RAVEN)
The problem has gone away. I eventually deployed some code and after that I could undeploy. Don't know what it was.
Code downloaded but not working... :( pudgeball C/C++ 4 28-01-2010 11:04
Undeploying code. NEED HELP dnrobotics11 C/C++ 3 01-02-2009 18:33
i downloaded the source code, now what do i do? programmr Programming 2 12-12-2008 14:39
Problems integrating CMUCAM code and IFI Default Code Windward Programming 2 06-02-2007 16:48
problems using gyro/adc code with camera default code tanstaafl Programming 7 22-01-2006 23:09
