Go to Post My first reaction was "Where am I am gonna find pool noodles AND inner tubes in the middle of winter in Michigan?" - KTorak [more]
Unread 06-02-2010, 18:43
ellisk ellisk is offline
FRC #1540
ellisk is on a distinguished road
Selecting autonomous modes using FRC PC Dashboard
I'd like to send information to the robot regarding position, balls, etc to let it know how to behave during autonomous. Last year, we used switches on our OI, but I wanted to know if I could use something analogous to switches on the FRC PC Dashboard to avoid having to build physical switches.
Thanks.
Unread 06-02-2010, 20:30
Re: Selecting autonomous modes using FRC PC Dashboard
If you do not plug in the I/O board and leave the Configuration set to the Compatible I/O, the four sliders and eight of the buttons are controls, meaning you can enter values in and they will be sent to the robot.
Greg McKaskle
Unread 06-02-2010, 21:12
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Closest thing you could do is a webserver on the robot for config. I think there are a few tutorials on how to do that
Unread 07-02-2010, 03:42
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
...which you could not access on the field. The FMS field network blocks all extraneous traffic like this.
Unread 07-02-2010, 08:55
Mike Mahar Mike Mahar is offline
FRC #0138
Mike Mahar will become famous soon enough
Be careful with this approach. We had problems last year. The data from the driver's station is sent during the disabled period and not during autonomous. We were reading the our autonomous mode from digital input pins on the driver's station and they were being sent to the robot properly. Just as the FMS was switching from disabled to autonomous, however, we would get one last packet that was full of garbage. This would set our autonomous mode to something random.
I don't know if this was an artifact for the old driver's station or something inherent in the comm system. If it's the comm system you will have to code around it.
Unread 07-02-2010, 10:31
Originally Posted by Mike Mahar View Post
Be careful with this approach. We had problems last year. The data from the driver's station is sent during the disabled period and not during autonomous...
The control system was modified to make this a bit easier this year. Definitely test it using the Practice mode, but I believe you'll find that the joystick throttles and I/O values are latched for you. The values during auto enabled will be the same as when disabled just prior to the match.
Greg McKaskle
Using FRC dashboard w/ camera during competition? asianfez123 FRC Control System 2 05-02-2009 15:56
Using FRC dashboard w/ camera during competition? asianfez123 Rules/Strategy 7 24-01-2009 22:07
multiple autonomous modes using easyc cerberus170 Programming 3 20-02-2007 15:01
Autonomous modes? Buster Robotics Education and Curriculum 4 17-03-2004 15:56
Selecting Autonomous Behavior Gobiner Programming 5 22-01-2003 09:44
