Go to Post Innovating for the sake of innovating, reinventing the wheel is probably the second biggest pitfall you can fall into when designing an FRC robot, if the wheel is already a very optimized, good solution. - Chris is me [more]
Unread 06-02-2010, 15:18
whatabouteve whatabouteve is offline
AKA: Dean Keithly
FRC #0245 (Adambots)
whatabouteve is an unknown quantity at this point
nivision.h errors C++
when we try and compile the "camera to dashboard" example code we get a repitition of these errors.
"C:/Windriver/workspace/CameraToDashboardExample1/nivision.h", line 818: error(etoa:4066): enumerated value is out of "int" range Polarity Type;
this reoccurs in the entire .h file preventing us from getting the first step to using the program.
We might just be making a silly mistake but there are over 100 errors in this one spot in the program.
Unread 07-02-2010, 03:50
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: nivision.h errors C++
I'm not sure, but I think that example might be obsolete. The 2010 Camera Demo includes vision to the dashboard. I recommend trying that one.
Unread 09-02-2010, 17:13
AKA: Dean Keithly
we fixed, not sure how because i didn't do it but a monkey did it so it couldn't have been that difficult.
Unread 10-02-2010, 00:01
Zme Zme is offline
FRC #2619
Zme is on a distinguished road
check the builder, if it isn't right then you will get a lot of errors very quickly
Unread 11-02-2013, 18:24
ronbaer ronbaer is offline
FRC #0612 (Chantilly Robotics)
ronbaer is an unknown quantity at this point
While this is an old post, the answer is still useful. (And I had the same problem today.)
Answer: Set the build environment to PPC603gnu
NIVision EllipseMatch Problems bronxbomber92 Programming 1 20-01-2010 07:59
nivision linking error 451Programmer Programming 4 10-03-2009 21:01
WindRiver Errors ExarKun666 C/C++ 7 04-03-2009 20:32
Errors on LabVIEW PHSRobotics NI LabVIEW 12 11-02-2009 10:00
NiVision.cpp nickmagus Programming 4 26-01-2009 08:55
