Go to Post FIRST is like pizza. You and I may like different toppings, but in the end it's still delicious pizza. - Billfred [more]
Unread 03-02-2010, 18:20
kennypu kennypu is offline
FRC #2467
kennypu is an unknown quantity at this point
outputting data to DS's usermessage
Is there a simple way instead of doing the whole packing,etc. thing in the DS example to output text to the 'user messages' section in the DS? Can you just eg just do cout<<"hello world" or printf() to output messages? Thanks.
Unread 03-02-2010, 18:50
1951-44U's Avatar
1951-44U 1951-44U is offline
ROAR.
AKA: Phil Chang
FRC #0025 (Raider Robotix)
1951-44U has a spectacular aura about1951-44U has a spectacular aura about1951-44U has a spectacular aura about
Re: outputting data to DS's usermessage
Look inside WPILib at the Dashboard.cpp file, especially at the function "Printf()". I think it allows you to print there, but I haven't tested it out.
Unread 04-02-2010, 01:47
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Yes.. use the DriverStationLCD class to write to the User Messages box on the Driver Station.
Unread 04-02-2010, 01:48
That sends to the dashboard, not the driver station. Use DriverStationLCD to write to the User Messages on the Driver Station.
Unread 04-02-2010, 11:46
Lucie365 Lucie365 is offline
FRC #0365
Lucie365 has a spectacular aura aboutLucie365 has a spectacular aura about
We have been trying to output data to the driver station using DriverStationLCD and have not been successful. We are doing everything exactly like we did last year (which worked fine)--we establish a pointer and do a "Get Instance" and then use a printf statement to send the message, but nothing is appearing in the driver station message space. Is there something different this year regarding the way it works?
Unread 04-02-2010, 12:02
Are you calling update?
slavik262's Avatar
slavik262 slavik262 is offline
We do what we must because we can.
AKA: Matt Kline
FRC #0537 (Charger Robotics)
slavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to behold
Send a message via AIM to slavik262
Wasn't the DriverStationLCD class created to print text to the actual physical screen of the Driver Station last year?
To my knowledge, you print strings to the User Messages region in the dashbard using the Dashboard class.
Unread 04-02-2010, 13:03
You can do that too, but to see it, you need to add a text display to your dashboard. The DriverStationLCD interface is implemented in the "User Messages" box for the new DriverStation. Any code that would print on the Blue DS's LCD will now print in User Messages box of the soft DS.
-Joe
Unread 04-02-2010, 21:32
FRC #0365
Thanks for the response. And yes..I forgot to call update. I will test it tomorrow but expect that was my only problem.
Unread 06-02-2010, 06:45
pafwl pafwl is offline
Franciose
AKA: Frank Larkin
FRC #0272 (Cyber Crusaders)
pafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud of
I used this feature very successfully last year but only on 1 line. I had high hopes for this year.
I started trying to use this but cannot get it to work. I am writing to one line again. In this case the pointer is locally declared each time I come into the function I am using to write it.
DriverStationLCD *p_dsLCD = DriverStationLCD::GetInstance();
p_dsLCD->Printf(DriverStationLCD::kUser_Line6, 1, "test" );
p_dsLCD->UpdateLCD();
I applied the last software update and now I get and errro on cRio boot.
Warning: module 0x134ad80 (FRC_UserProgram.out) holds reference to undefined symbol _ZN16DriverStationLCD11kLineLengthE.
(unloading partially loaded module FRC_UserProgram.out)
...FRC_UserProgram failed to load.
If I comment out his code I am fine.
Any ideas?
Unread 06-02-2010, 10:25
bronxbomber92 bronxbomber92 is offline
FRC #1551 (Grapes of Wrath)
bronxbomber92 is an unknown quantity at this point
Have you tried doing a clean and build?
Unread 06-02-2010, 11:30
Thyn Thyn is offline
FRC #1504
Thyn is an unknown quantity at this point
We are also having pafwl's issue, and will post if we figure anything out. Cleaning does not resolve the issue.
Unread 06-02-2010, 13:36
sunit sunit is offline
FRC #1504
sunit is an unknown quantity at this point
Clean and Build did not fix the issue.
We commented out all the lines that use DriverStationLCD and that did not fix the issue.
At this point we are in the process of reinstalling WindRiver workbench and not install the latest patch.
Can someone please assist.
Thanks,
Sunit
Unread 07-02-2010, 09:07
Mike Mahar Mike Mahar is offline
FRC #0138
Mike Mahar will become famous soon enough
We are also having this problem with kLineLength. When we comment out the DriverStationLCD code the problem goes away. I looked at the new source code for the library and I didn't see anything obvious as to what would cause this. I'm beginning to suspect that something went wrong with the wpilib.a build in the latest update.
I haven't tried building the WPILIB from sources yet.
Unread 07-02-2010, 23:32
LyraS LyraS is offline
FRC #2102
LyraS is an unknown quantity at this point
We are also having the same problem. Anyone have a workaround for this?
Voltage not outputting to the Drivers Station Ryutso Electrical 8 09-02-2010 11:39
Periodic Task Data --> Robot Data Kahn! NI LabVIEW 3 10-02-2009 19:38
Sending user data, parsing user data. demosthenes2k8 NI LabVIEW 3 30-01-2009 13:51
PWMs not outputting in Autonomous 937Programmers Programming 15 08-02-2007 21:25
