Go to Post Robotics is my football! - Nemo [more]
Unread 07-02-2010, 09:50
DaSavageJ DaSavageJ is offline
FRC #3011
DaSavageJ is an unknown quantity at this point
Normal IO Push Button on the Digital Sidecar
Does anyone know of a way I can connect a normal open close push button, using only power (negative and positive) connectors, to the Digital Sidecar?
Unread 07-02-2010, 09:56
gbf1991 gbf1991 is offline
FRC #3011
gbf1991 is an unknown quantity at this point
Re: Normal IO Push Button on the Digital Sidecar
I'm from the same team, and we're trying to set up an auto shutoff for a motor based on a sensor switch. In order to simulate this, since we don't have the switch yet, we're using a pushbutton. Any help would be appreciated.
Unread 07-02-2010, 10:13
To connect a button or switch to the Digital Sidecar you use the ground (-) and signal pins, not the power (+) pin.
Anything you want your code to know about MUST use the signal pin to "signal" the cRIO. That's the only way your code can "hear" anything.
So connect the switch ground to (-) on the Sidecar and the switch (+) to the signal pin on the Sidecar.
Unread 07-02-2010, 17:28
FRC #3011
Thanks a lot man, I'll try this out first thing in the morning.
Unread 07-02-2010, 17:43
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Make sure you connect it to the digital I/O pins - the same place you'd plug in an encoder.
Relay Ports on the Digital sidecar have no Power 10uhingp Electrical 6 30-01-2010 14:00
Attaching a standard car relay to the Digital sidecar KillerGardevoir Electrical 4 02-08-2009 21:26
Driver Station Push Button coolperson987 General Forum 6 12-03-2009 22:17
Push Button System Rob2713g Programming 5 08-08-2006 21:20
push-button switch on robot Conan Electrical 4 10-02-2006 22:03
