Go to Post Careful what words you use here; we take them literally. - DonRotolo [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 07-02-2010, 10:42
Shinigami2057 Shinigami2057 is offline
Slackware Is Your New God (Mentor)
AKA: Harry Bock
FRC #1350 (Rambots)
Shinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really nice
Re: Our CAN Tale of Woe
You can use off-the-shelf cables - CAN-to-CAN connections (not serial-to-CAN) use 6P4C connectors, which means you can use standard RJ-11/RJ-12/RJ-25 phone cable. The only "non-standard" cable is the serial RS-232 cable you make for using the Black Jaguar as a bridge. This can be made with (standard) RJ25 phone cabling, a DB9 modular adapter, and a 100 ohm resistor as show in the Getting Started Guide. All of these were listed with corresponding Digikey part numbers.
I think the moral of the story is for teams to read the directions, twice (perhaps there is an EE analogue of 'measure twice, cut once'). The Jaguar manuals were very clear in the requirements for making the bridge cable. If you try and hack together hardware like many teams (including our team) hacks at code, without reading the directions, you'll get bitten pretty hard.
One of the main causes of the fall of the Roman Empire was that, lacking zero, they had no way to indicate successful termination of their C programs.
Vid: Our drive team can-can dance.... OScubed Chit-Chat 1 13-04-2008 12:04
The Amusing Tale of Mtrawls/1418 phrontist Chit-Chat 5 16-06-2004 22:02
A Tale of Ten Thousand Crashes Nero 3D Animation and Competition 19 16-03-2003 22:21
A Krispy Kreme Fairy Tale MissInformation Chit-Chat 23 15-05-2002 10:36
