Go to Post JVN, thanks for working with me. You will make a great MC anywhere. Folks, he actually loosened up and fit right in. - Steve W [more]
Unread 07-02-2010, 12:53
mark.amber mark.amber is offline
FRC #2039
mark.amber is an unknown quantity at this point
We have some things working with java, if you need help look here
I am creating this thread because we needed some help getting all the things working on the robot.
We are using the following computer systems for programming in JAVA:
  • Ubuntu 64 bit, running netbeans 6.8 successfully (Ubuntu 9.10)
  • Ubuntu 32 bit, running netbeans 6.8 successfully (Ubuntu 9.10)
  • Windows Vista, running netbeans 6.8 successfully
Classmate PC running:
  • Netbeans 6.7.1. we do not use netbeans on the classmate
  • Updated driver station with compass in bottom right.
  • Recieving feed of camera from cRIO.
  • Working comunication.
The cRIO:
  • Using Victors.
  • Connected to camera, seems to run the default circle detection code, follows circles with this code.
  • Connected to a WGA600N Gaming adapter, connected to our local network, all Computers listed can download to it.
  • Working Gyro for compensating for the orientation of the robot.
  • Working Servo for adjusting camera angle.
Code contains working sections for:
  • HolonomicDrive: setup so no matter what direction the robot is heading, it will respond to the joystick the same (using mecnum wheels)
  • Controls camera position on servo using a throttle on Attack3 Joystick.
  • Using iterativerobot class
  • Using multiple methods, so the code is segmented, and easier to debug
  • Debug output to Netbeans working.
Procedures we know
  • We know the procedure to download code to the cRIO from Netbeans (complicated).
  • We know how to flash the cRIO with the latest image.
  • We know how to setup the Axis camera, for use on the cRIO.
  • We know how to use the Vision Assistant 2009 to test out different filters.
  • We know how to install the latest updates for driver station (complicated).
Just respond to this thread if you want to know how to do one of these things, just quote it, and tell any relevant information.
Really need some help here... synth3tk General Forum 5 23-05-2008 17:29
Need some help with arm not working... neilcooper Programming 3 15-03-2008 06:16
can i have some help with quadratic equations CmptrGk Math and Science 9 13-12-2004 21:33
Have you ever had fish as a "pet"? If so look here please! Elgin Clock Chit-Chat 15 24-11-2004 19:11
hey need some help with writing a code please help me here magical hands Programming 9 01-01-2004 21:46
