Go to Post Analysis is a tool. Like any other tool you need to figure out where and when to use it. That's the tricky part. - ChrisH [more]
Unread 07-02-2010, 13:34
grosh grosh is offline
FRC #2147
grosh is an unknown quantity at this point
Attaching a small gear to Denso window motor?
We are trying to attach a small gear to the Denso window motor. Currently we have mocked up the window motor to the coupler...coupler to shaft...gear on shaft. This works but is very bulky. There must be a better way.
Any ideas on how to modify the coupler to attach a small gear/sprocket?
Has anyone modified the plastic motor output "gear" that the coupler attaches to? is modifying this motor part legal?
IDEAS?
Setting Up a Denso Window Motor RyanJK Motors 6 19-01-2009 14:33
Denso Window Motor Connector scottydoh General Forum 2 10-01-2009 14:43
What is a denso window motor? Team2441 Motors 5 27-01-2008 13:04
Attaching Denso motor adapter to the motor? Billfred Motors 3 19-02-2007 20:07
Denso Window Motor gear profile? Joshua Lynn Inventor 2 23-01-2006 23:57
