Go to Post Fun is not where you find it but where you make it. - Foster [more]
Unread 07-02-2010, 13:34
grosh grosh is offline
FRC #2147
grosh is an unknown quantity at this point
Attaching a small gear to Denso window motor?
We are trying to attach a small gear to the Denso window motor. Currently we have mocked up the window motor to the coupler...coupler to shaft...gear on shaft. This works but is very bulky. There must be a better way.
Any ideas on how to modify the coupler to attach a small gear/sprocket?
Has anyone modified the plastic motor output "gear" that the coupler attaches to? is modifying this motor part legal?
IDEAS?
Unread 07-02-2010, 13:52
John G John G is offline
FRC #0399 (Eagle Robotics)
John G is on a distinguished road
Re: Attaching a small gear to Denso window motor?
From what I know, we're just using set screws and it seems to work reasonably well.
Unread 07-02-2010, 14:32
FRC #2147
I found a good example...
I like this solution BUT the plastic output "gear" on the motor scares me. Is it legal and/or practical to replace it with an aluminum output gear?
Any other ideas?
Name:	Denso window motor gear.jpg
Unread 07-02-2010, 14:49
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
You will need to ask on the Q&A for a legal answer, but the general concensus I've seen is that the plastic portion on the output is needed for that motor because it is considered to be an integral piece.
There is not prohibition about machining your own coupler instead of the using the provided plastic plastic one. However, be careful because those window motors can be touchy about shear loads (in our experience from 07).
Setting Up a Denso Window Motor RyanJK Motors 6 19-01-2009 14:33
Denso Window Motor Connector scottydoh General Forum 2 10-01-2009 14:43
What is a denso window motor? Team2441 Motors 5 27-01-2008 13:04
Attaching Denso motor adapter to the motor? Billfred Motors 3 19-02-2007 20:07
Denso Window Motor gear profile? Joshua Lynn Inventor 2 23-01-2006 23:57
