Go to Post In all seriousness, here's a thought for everyone: Don't worry about what you can't control. - Rich Kressly [more]
Unread 07-02-2010, 10:22
aechmtwash11 aechmtwash11 is offline
FRC #2783
aechmtwash11 is an unknown quantity at this point
Questions
Hey CD world,
we are a second year FRC team but have not used pneumatics for actual competition. So of course we have a couple questions.
The rules state that the safety pressure release must be directly connected to the compressor. So does this mean it must be physically touching the threads coming out of the compressor or can we have a couple T's between it and the compressor.
Can we turn the top of the compressor so that the B port is where the A port is normally?
Our current setup has two separate storage areas,so we have two storage pressure regulators. Are we allowed to do this?
Thanks,
Austin
2783=2010
Unread 07-02-2010, 12:33
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Re: Questions
The FIRST pneumatics manual should have answers to most, if not all, your questions.
--Ryan
FRC 766, 2015-, Mentor
Unread 07-02-2010, 12:39
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Questions
and the Q&A should have the rest of the answers, if you ask the right questions.
http://forums.usfirst.org/forumdisplay.php?f=23
My somewhat educated guess is that you need to screw the pressure relief valve directly into the compressor, and you need to leave the screws that hold it together, alone.
Unread 07-02-2010, 12:41
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
Re: Questions
Also there is a lot of helpful information on here
http://www.team358.org/files/pneumatic/
Thank you 358!
Team 2228(FRC) - Drive Team Lead, Drive Coach, Mechanical Team
Team 3750(FTC) - Team Lead
2009
Team 2228(FRC) - Mechanical Team, Driver at RIT, and Hartford Regionals, and Drive coach at Ruckus
*Second Place at Ruckus
Team 3750(FTC) - Team Lead, and Drive coach at Clarkson Regional
*Second Place at Clarkson Regional
2008
Team 1930(FRC) - Worked on Mechanical, Electrical, and Programming.
Unread 07-02-2010, 12:53
Re: Questions
Part one of your answer lies here...
<R77> The relief valve must be attached directly to the compressor. Teams are not allowed to adjust the 125-psi relief valve.
If you are asking as to which port the relief valve is located, the answer is either side that is convenient they are both output ports.
If you are asking, can you have two of your storage tanks be on the low pressure side, then the answer lies here in <R76>...
B. Only the compressor, relief valve, pressure switch, pressure vent plug valve, pressure gauge, storage tanks, tubing, and connecting fittings may be in the high-pressure pneumatic circuit upstream from the regulator.
This gives you max storage anyway. You may have an additional regulator(s) on the low pressure side following the main 60 psi regulator.
Unread 07-02-2010, 12:56
MrForbes's Avatar
AKA: Jim
Re: Questions
Aren't the two ports different size pipe thread? Might make it hard to put it on the most convenient side without taking the top off the compressor and turning it around, which might violate the "pneumatics parts are sacred" rule?
Unread 07-02-2010, 13:03
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Questions
According to the diagram here (Pg 5), one port is 1/8-27 NPT, the other is 1/4-18 NPT
Unread 07-02-2010, 13:15
Re: Questions
Yes, they are, but the answer merely responded to the question.
Unread 07-02-2010, 15:01
FRC #2783
Re: Questions
I think I need to better explain my questions.
On the safety pressure release, we are trying to fit the system in a very small spot. So we are trying to fit all the FIRST required sensors and such to be on the side of the compressor with the motor. Because of this it is requiring us to have the pressure release between a set of T's and the compressor. (is this allowed?)
Flipping the top of the compressor was just to make it easer so we wouldnt have to go through another down-sizer
On the pressure regulater, we are having the air flow immediately split into two systems once it exits the compressor. So essentially we have a system for the right side of the robot and a system for the left. So can we have two main regulators?
We have checked the pnuematics manual but it says on the first page that it is just for suggestions and are not official rules.
Thanks Again,
Austin
2783=2010
Unread 07-02-2010, 15:09
MrForbes's Avatar
AKA: Jim
Re: Questions
can you just screw the pressure relief valve into the motor side, then attach a 90 degree quick connect hose fitting into the other side, and run a plastic tube to the rest of the stuff?
Unread 07-02-2010, 16:13
Generator of Entropy
FRC #2973 (The Mad Rockers)
Re: Questions
Careful; although rotating the top of the compressor looks pretty straightforward (and it is), when the question of whether or not we were allowed to do it was posted to the Q&A a few years ago (expecting a "yes" answer"), the answer was a solid "NO".
See this post
Unread 07-02-2010, 16:44
FRC #2783
Re: Questions
Thanks Gary!
One down two to go.
Unread 07-02-2010, 16:46
MrForbes's Avatar
AKA: Jim
Re: Questions
That's the ruling I had in mind....thanks Gary for finding it
Ask Q&A about the safety valve needing to be directly on the compressor.
It should function just fine if it's on a T that is connected directly to the compressor, but there may be some reason the GDC does not want you to do that?
Unread 07-02-2010, 17:55
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: Questions
It is possible if a fitting is placed between the compressor and the relief valve, that it could affect the discharge rate of the relief valve. The inspectors would have no way of determining this with a visual, external inspection.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 07-02-2010, 23:03
Re: Questions
On the question of disassembling the compressor head and reorienting the answer would be no. You may not modify any of the pneumatic parts. See R73 for a complete list of items not allowed in the pneumatic system.
On the question of splitting the high pressure side to feed two sides of the robot, this part of rule R72 would seem to indicate it is allowed.
G. Pressure regulators with a maximum bypass pressure of no more than 60psi.
However to satisfy the other parts of the pneumatic rules, the second regulator would also need a gauge to indicate 60 psi.
As to the question of adding a "T" fitting to allow the relief valve to be mounted at the compressor, there does not appear to be any rule that would prevent it. The intent of the pressure relief valve is to protect the system in the case of a failure in the pressure switch and a blockage in the output of the compressor. I believe that a "T" would fulfill this safety feature. However, a team must ask this question on the Q&A.
Bumper Zone Questions (was Misc. Questions) viperred396 General Forum 9 10-01-2010 12:09
3 Questions!!! (2/2/04) Andy Grady General Forum 18 02-02-2004 22:18
3 Questions!!! (1/30/04) Andy Grady General Forum 14 02-02-2004 08:51
3 Questions!!! (1/29/04) Andy Grady General Forum 8 29-01-2004 16:36
3 Questions!!! (1/5/04) Andy Grady General Forum 8 05-01-2004 16:01
