Go to Post Powerhouse teams aren't powerhouse because they build great robots, they are powerhouses because they build great teams. - couvillion [more]
Unread 28-01-2010, 21:42
hunter7193 hunter7193 is offline
FRC #0548 (Robostangs)
hunter7193 is an unknown quantity at this point
Classmate Problems
Well, from searching the forums I have found nothing on this problem that we (Team 548, Robostangs) are having with our classmate pc. After about two hours of the classmate being turned on, it overheats and shuts down. Is anyone else having this problem or do we have to send ours back?
Unread 28-01-2010, 21:53
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
Re: Classmate Problems
That definitely sounds like an isolated incident. I wouldn't recommend opening yours up to see if the CPU fan is running as this would probably violate any sort of warranty with FIRST. Call FIRST and ask about tech support/replacement. It might be as simple as a loose wire connecting the fan to the motherboard.
Unread 28-01-2010, 23:02
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
We leave ours running 9 hours straight on our weekend build and have no problems.
As a warning, try not to use it. We had a laptop with a bad fan that we couldn't fix. Opened it for the first time this year and found that we couldn't boot. Even on a cooling pad it will just get worse
Download the Driver Station update to some other computer that has LabVIEW installed and install the update. You should be able to use that until you can get a replacement for the classmate.
Unread 29-01-2010, 14:53
For hardware problems with the FRC Classmate, FIRST has told us to contact the 2gopc help desk directly:
Unread 06-02-2010, 14:01
robotic321's Avatar
robotic321 robotic321 is offline
FRC #1793
robotic321 is an unknown quantity at this point
Question Re: Classmate Problems
Anyone else having a issue with the Classmate just blacking out while running code? This happened to us twice : once right after running code and again at about 3 mins into running the same code.
Unread 07-02-2010, 16:44
AKA: Ian Thompson
What do you mean by blacking out? Screen going black but responds to keyboard? Entire system freezes and DS connection is lost? Most likely the computer is just putting the screen into power save. That can be disabled on the Developer account
Classmate PC lon.bushweiler Control System 8 22-01-2010 14:46
classmate problems dnrobotics11 Control System 4 18-01-2010 02:02
Classmate MachineSMMC NI LabVIEW 10 15-01-2010 13:47
classmate help!!! a kenny03 General Forum 1 13-01-2010 20:33
Problems Interfacing '10 Control System w/ Classmate 1951-44U FRC Control System 14 11-01-2010 06:30
