Go to Post The flux capacitor should have been allowed under the flowchart as long as it met the single component maximum cost. I did check with Digikey and they no longer carry the line. - Al Skierkiewicz [more]
Unread 07-02-2010, 17:24
Alexandstein Alexandstein is offline
FRC #2192 (YAK Attack)
Alexandstein is an unknown quantity at this point
Compressor not working.
Our compressor seems to not be functioning properly. If we just apply a power source straight to the compressor it functions fine. We checked the programming and it seems fine. (Begin: Open Compressor(DIO-1, Relay-1)->Start->Devref) When we try to run the code on the robot and then enable it, the compressor fails to run each time. We tried to replace the Spike attached to the relay and compressor but nothing happened.
Any help with setting up the compressor?
Thanks a lot!
Compressor NOT Working (multiple trials already) Noel Pneumatics 10 02-02-2009 18:38
p2 not working? Lone_Wolf92c Programming 5 22-02-2008 08:49
IR Board Not Working (But NOT Fried) itsme Electrical 2 18-02-2008 06:11
cam not working :( magical hands Programming 3 05-02-2005 21:45
Radios not working... E Jones 234 Electrical 3 21-01-2005 21:58
