Go to Post Just so you don't spend too much time on non-clues ... now you can all go back to the real one! :D - Libby K [more]
Unread 04-02-2010, 18:29
bfighter bfighter is offline
FRC #2579
bfighter is an unknown quantity at this point
how to set up the gyro?
hey.
We're trying to set up the gyroscope, but we're having trouble understanding the intrusctions here: http://www.usfirst.org/uploadedFiles...ual%20RevA.doc
can anyone help us out and guide us on how to set up the gyroscope succesfully?
Thank you so much.
Bruno Melofiro - Team 2579, LIC robodogs
Unread 04-02-2010, 18:32
Re: how to set up the gyro?
Thank you for reading the instructions!!
Can you help us by telling us what part you are having difficulty with?
Unread 04-02-2010, 18:42
FRC #2579
I wanted to know if the link I gave below were the instuctions.
Unread 04-02-2010, 20:06
dmitch's Avatar
dmitch dmitch is offline
Chief Head Electrical Guy
AKA: Daniel Mitchell
FRC #1997 (Stag Robotics)
dmitch is a jewel in the roughdmitch is a jewel in the roughdmitch is a jewel in the roughdmitch is a jewel in the rough
bfighter, we use LabView. When we open it there is an examples pane on the right side of the open screen. We can click on the example for the gyro. If you don't have LabView sorry, but that's how our team wired it up.
Unread 07-02-2010, 17:49
LiquidMagik LiquidMagik is offline
FRC #0649
LiquidMagik is an unknown quantity at this point
Gyro has been hooked up via PWM to the cRIO. How do I get it to talk with the java on NetBeans?
Unread 07-02-2010, 20:35
PWM connections are outputs from the Digital Sidecar. You need to connect the gyro to input 1 or 2 on the Analog Breakout in order for the cRIO to be able to read it.
Unread 13-02-2010, 13:50
seathroath seathroath is offline
FRC #2051
seathroath is an unknown quantity at this point
our gyro is connected to the analog breakout on the cRIO but we still are not getting anything.
Steps to a Successful Program
1. Load labview software
2. Try to build program
3. Fail to save program on cRIO
4. Look on internet for help
5. Throw chair
6. Drop computer out window
7. Hate life
8. Want to strangle your mentor
9. Find help on internet
10. Program works!
Don't skip steps 5-8, they are important for success
how to attach the gyro sensor on the robot dazero Sensors 1 02-03-2009 13:16
How to set the deadband in motor vi RickErmer NI LabVIEW 1 16-02-2009 20:07
[FTC]: Anyone know how to use the Gyro? ttldomination FIRST Tech Challenge 0 31-01-2009 21:19
How do I change the Gyro & Acc analog chanels? TEAM1949 Programming 7 14-02-2008 12:42
How do you set a speed limit on the servo Fares Programming 6 01-01-2003 15:04
