Go to Post teams that REALLY deserve to win will find ways to overcome a marginal officiating decision. Also, teams that REALLY deserved to win will try not to put themselves in that position. - Chris Hibner [more]
Unread 07-02-2010, 17:19
daltore's Avatar
daltore daltore is offline
Electronics/programming/design
AKA: Aaron Osmer
FRC #3529 (ausTIN CANs)
daltore has a spectacular aura aboutdaltore has a spectacular aura aboutdaltore has a spectacular aura about
Send a message via AIM to daltore Send a message via MSN to daltore Send a message via Yahoo to daltore
pic: Telescoping Arm Warning
Unread 07-02-2010, 17:21
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: pic: Telescoping Arm Warning
Thanks for the pic. Your post brings up a good point. Not only do you have to be wary of mechanical advantage. Putting a knot in a line ('rope' for you non-sailors) will lower the breaking strength by nearly 40%! The 'correct' way once you know your required line lengths would be to use a thimble (not the sewing kind) and have the line spliced, or you can mearly account for the reduction in strength due to the knot and use larger line.
Unread 07-02-2010, 17:50
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
This is an asterisk on Tom's good advice:
Anything (including a thimble) that puts a curve into the line lowers the force it can survive without breaking. The fibers on the inside of the curve go slack a little bit and contribute less to the strength of the total line; and consequently the fibers on the outside (that are now carrying more load) break under less load than a straight line could survive. Each individual fiber is as strong as as ever, but fewer of them are sharing the total load.
Using a thimble's "gentle" curve reduces the breaking point less than an ordinary knot with a severe (small radius) initial curve; but I wouldn't want anyone to think that using a thimble allowed you to avoid the strength reduction entirely. Even with a thimble you have to account for some loss of load-carrying ability.
Blake
Unread 07-02-2010, 18:42
Ahnxlazyman's Avatar
Ahnxlazyman Ahnxlazyman is offline
Andrew
AKA: Andrew nguyen
FTC #0116 (Epsilon Delta)
Ahnxlazyman is a splendid one to beholdAhnxlazyman is a splendid one to beholdAhnxlazyman is a splendid one to beholdAhnxlazyman is a splendid one to beholdAhnxlazyman is a splendid one to beholdAhnxlazyman is a splendid one to beholdAhnxlazyman is a splendid one to behold
Send a message via AIM to Ahnxlazyman
your stick figures weren't wearing safety glasses. unsafe!
but I hope you guys solved the problem though, and I hope no one got hurt
Unread 07-02-2010, 19:10
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
This is my biggest fear when it comes to suspending from another robot. Will you be willing to trust all your hard work to another teams calculations and design?
Unread 07-02-2010, 19:39
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
It seems to me that the easiest solution would be to triple or quadruple up your line. Effectively gives you a 4000 pound breaking limit instead of 1000.
We're using parachute cord (which has a breaking point of 500 pounds) and are quadrupling it. It's a lot easier to tie than spectra.
"we don't build robots, we build people"
Unread 07-02-2010, 20:59
Sh1ine Sh1ine is offline
FRC #2791
Sh1ine is on a distinguished road
Check out AmSteel Line. It is designed to replace stainless steel rigging on sailboats. Size for Size AmSteel is stronger then stainless, at 1/7th the weight. Plus, it is very flexible.
Unread 07-02-2010, 21:30
daltore's Avatar
AKA: Aaron Osmer
Yeah, I'm actually going to West Marine Supply tomorrow to pick up some 3/16" AmSteel Blue line. Instead of the 1/8" harpoon tether cord we've been using with a breaking strength of 1050 pounds (made of Spectra A, the weaker of the UHMWPE forumlations), the new stuff will have a breaking strength of 5000 pounds and is made of Dyneema (next step up, right before Spectra B).
Thanks for all of your suggestions, and the concerns for our safety. Richard and I were fine, as we were expecting a hitch pin to break anyway, so we were holding on in a way that allowed us to both catch the robot and land on our feet.
Unfortunately, we don't have the luxury of using a thimble in our setup, as it would be too large, and our tensioning system uses eye loops that are welded shut, so the standard overhand knot using the loop won't work. Do you have any suggestions for the best kind of knot to use in this situation?
Unread 07-02-2010, 21:44
KC1AJT's Avatar
KC1AJT KC1AJT is offline
Head Mentor
AKA: Patrick
FRC #6617 (Bellinghan High School Black Hawks Robotics Club)
KC1AJT is an unknown quantity at this point
i would recommend 2 half hitches http://meritbadge.org/wiki/images/5/...cout-Knots.pdf
Mentor - Team 6617
_____________________________________________
Student Years - Team 61
2011 Boston Regional
2011 BAE Systems/Granite State Regional
2010 Northeast Utilities FIRST Connecticut Regional Finalist
2010 Boston Regional
2009 Archimedes Division
2009 Connecticut Regional
2009 Boston Regional Regional Winner
Unread 07-02-2010, 22:49
gblake's Avatar
AKA: Blake Ross
no team (6th Gear)
A Google search using "thimble" "knot" "load" "line" turned up this link to a Knot blog, along with a few other leads. The blog entry is a bit tedious; but it has some useful info in it and it has some references to knot-tying reference material (near the bottom).
http://allaboutknots.blogspot.com/20...hitch-for.html
Blake
Unread 07-02-2010, 22:58
Rion Atkinson's Avatar
Rion Atkinson Rion Atkinson is offline
The CAD Guy
Rion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond repute
If that team was FRC 111 (Simbotics) or FRC 148 (Robowranglers) I would do it in a heart beat.
‎‎"I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. -Albert Einstein
Start Something
Email - rionatkinson@gmail.com
Skype - Rion.Atkinson
Unread 08-02-2010, 02:59
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Note:
FRC 111 is Wildstang
FRC 1114 is Simbotics
Unread 08-02-2010, 03:14
And if it was 111, 1114, or 148, I'd do it in a heartbeat... (There are a few other teams, too.)
Unread 08-02-2010, 07:48
ltdboarder101 ltdboarder101 is offline
FRC #3098
ltdboarder101 is an unknown quantity at this point
this is why you do not use your arm to pull up the robot.
you use something else to pull u up
Unread 08-02-2010, 07:54
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
If your second telescoping stage was moving twice as fast as the first then it has a 2x mechanical advantage and sees only 1/2 the force of the first stage, not twice the force. Otherwise you'd magically be getting free work, which we all know is impossible.
Edit: We're using 1/4" vectran rope from McMaster, which has a working load of 1500lbs. Make sure whatever rope or cable you're using has a WORKING LOAD in the range you want that that you're never exceeding any bending allowance.
Telescoping arm Jeff 801 Technical Discussion 12 15-06-2007 14:41
Telescoping Arm ArmoredFairy698 Technical Discussion 17 14-06-2005 11:26
Chain Driven Telescoping Arm BadKarma Technical Discussion 8 05-06-2005 12:19
pic: Team 930 telescoping arm CD47-Bot Robot Showcase 1 13-02-2004 16:24
telescoping arm CharlieWilken Technical Discussion 45 26-01-2004 22:22
