Go to Post People will only work toward common goals when they are part of the goal-setting process. - GaryVoshol [more]
Unread 26-01-2010, 15:31
jwj3027 jwj3027 is offline
FRC #3229
jwj3027 is an unknown quantity at this point
i need help
i tried using the videos on how to use labview but it wont help. does anyone know a video or a place that i can get to that is free and not on youtube.
thanks
jwj3027
Unread 26-01-2010, 15:41
sloteera's Avatar
sloteera sloteera is offline
AKA: Rafa
FRC #1860 (Cephatron)
sloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud of
Re: i need help
thanks
jwj3027
Did you try the frcmastery.com ???
I hope that could be useful to you!
Unread 26-01-2010, 15:47
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Re: i need help
So I did the obvious thing and entered "labview tutorial video" into the ask.com search engine. At the top of the list was http://zone.ni.com/devzone/cda/tut/p/id/7466 It's the developer zone at National Instruments. I'm pretty sure NI wants you to be able to use their product. There are more videos available there at which you couldn't shake the proverbial stick. They are arranged in a logical sequence, so start at the beginning and skip forward ONLY if you find yourself yawning a lot.
Unread 26-01-2010, 16:00
mswalker mswalker is offline
FRC #2583 (Westwood Robotics)
mswalker is on a distinguished road
Re: i need help
You might also look at the manuals installed with Labview under: c:\Program Files\National Instruments\LabVIEW 8.6\manuals (if you installed LabView under c:\program files). There is an FRC_Getting_Started.pdf and FRC_Programming_Guide.pdf that contain a lot of useful information.
Unread 26-01-2010, 16:01
FRC #3229
Re: i need help
thanks for the advice. oh new question does anyone know how to program with pnumatics
Unread 26-01-2010, 16:05
Electrical Engineer
Rookie Year: 1995
Re: i need help
I strongly second Rafael's post: http://frcmastery.com/ (the "Try Me" section).
Regards,
Mike
Mike Betts
As easy as 355/113...
Unread 26-01-2010, 16:55
Re: i need help
There is an example you can look at.
It's on the bottom right of the LabVIEW startup screen.
Unread 04-02-2010, 16:07
FRC #3229
Re: i need help
hey guys thanks. That helped alot, one last question, how do i program the pnuematic system and my team is completely lost. Please send a reply as soon as possible.
Thanks
jwj3027
Unread 04-02-2010, 16:37
rsegrest's Avatar
rsegrest rsegrest is offline
@ least I'm OVER the rock THIS time
FRC #2582 (PantherBots)
rsegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant future
Re: i need help
I completely understand about your issues. Check out this link hosted by Team 358. It has a TON of info about pneumatics including how to wire it to the cRio and screenshots of programming it in LabView.
http://www.team358.org/files/pneumatic/
Hope this helps!
Impossible is just a big word for small men who find it easier to live in the world they've been given than to explore the power they have to change it. Impossible is not a fact. It's an opinion. Impossible is not a declaration. It's a dare Impossible is potential. Impossible is temporary. Impossible is nothing.
~ Unknown
Unread 05-02-2010, 15:31
FRC #3229
Re: i need help
so we were trying to get the robot to work now, but last night we had to flash the driver station. We have set it back up but the cRIO wont respon to the program. Now what.
Unread 05-02-2010, 16:36
FRC #3229
Re: i need help
oh while i was working on frcmastery i run into the problem that after i did everything that i was told to do the program was still consider broken. Is this supose to happen on frcmaster.com video 4 frc walkthrough.
Unread 07-02-2010, 22:05
LVMastery LVMastery is offline
LabVIEW Educator and Mentor
AKA: Ben Zimmer
FRC #0843 (Wildcats)
LVMastery has much to be proud ofLVMastery has much to be proud ofLVMastery has much to be proud ofLVMastery has much to be proud ofLVMastery has much to be proud ofLVMastery has much to be proud ofLVMastery has much to be proud ofLVMastery has much to be proud of
Re: i need help
Hi everyone. Thanks for the kind words about frcmastery.com!
JWJ: have you upgraded to the latest upgrades of LabVIEW, Driver Station, and then done an update of the cRIO firmware. If not, you should.
As for the broken VI... there are some debugging features of LabVIEW which can help narrow it down. Try clicking the run arrow. What does it say in the error list?
Ben
-- FRCMastery.com team
Ben Zimmer
Enable Education
www.EnableEducation.com
www.FRCMastery.com
email: ben@enabletc.com
Phone/Fax: (905) 864-1858
Toll Free: (877) 872-4619
Unread 09-02-2010, 15:00
FRC #3229
Re: i need help
yes i have upgraded the driver station, my labview soft ware, and every thing. I tried clicking on the debug but i still cant get it to tell me where my problem is.
Thanks JWJ
Unread 12-02-2010, 16:19
FRC #3229
Re: i need help
my team has finshed programming the robot. We are now wondering what game controller would be the most intersting and relatively easy to program.
need help assembling parts in inventor .. (was: help) jhallel Inventor 5 22-02-2007 01:46
hey need some help with writing a code please help me here magical hands Programming 9 01-01-2004 21:46
HELP!! i need help starting a new team!! shyra1353 Starting New Teams 18 07-10-2003 17:55
