Go to Post Sometimes, it's all about the people. - nixiebunny [more]
Unread 07-02-2010, 19:40
ssica_jj ssica_jj is offline
FRC #0368 (TKM)
ssica_jj is an unknown quantity at this point
problems with using switches for autonomous
For our team autonomous, we decided to use switches for autonomous. We connected the Cypress board and the breadboard to wire up the switches. The value from the switches are being displayed on the driver station(classmate) but somehow, the program is not reading the value. The only value that it reads is 0. Even when we flip the switches, the value on the laptop does not change. (However, the value on the driver station is changing without any problems.)
Could anyone please help us on this problem?
Thank you!
EDIT*
The values from the switches are being read by the Classmate Driver Station, but not on the programming laptop (separate from the Classmate). It shows change on the Classmate Driver Station, but not on the programming laptop.
Unread 07-02-2010, 21:22
Re: problems with using switches for autonomous
The value is being displayed, but it isn't being read? It's changing, but it isn't changing? I don't understand what you're saying.
Unread 07-02-2010, 21:24
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Why not put the switches on the robot, connected to the digital IO on the digital sidecar?
Unread 07-02-2010, 21:27
FRC #0368 (TKM)
the values(boolean) is being displayed on the driver station, under the I/O tab, but not in the program on LabVIEW when you run it. It changes between 1 and 0 on the display on the driver station but not in the program.
I don't know how you would go about putting the switches on the robot. We have always put the switches with the driver station. We would like to keep it this way, however, we are willing to try another way if it is not possible to program the switches with the driver station.
Unread 07-02-2010, 22:13
How are you determining that the value is not being read in LabVIEW? If you show us your code, we might see something that's not doing what you think it is.
Unread 07-02-2010, 22:32
FRC #0368 (TKM)
We ran the RobotMain.vi in the project containing the code. We connect the laptop to the router which is connected to the driver station.
Attached is a screen shot of our code.
Unread 07-02-2010, 22:47
Acshi Acshi is offline
FRC #2924
Acshi is an unknown quantity at this point
Might it will only work during disabled mode and once it moves into autonomous mode the correct reading are overridden with incorrect ones? That might make sense since, you only have to read once and they might want to insure no active data is going to the bot in autonomous mode...
Unread 07-02-2010, 22:51
FRC #0368 (TKM)
Even though it is in the Disabled.vi, it should be reading it, however it doesn't read whether it is enabled or disabled.
Unread 07-02-2010, 22:55
bls0620's Avatar
bls0620 bls0620 is offline
FRC #0368 (Team Kika Mana)
bls0620 will become famous soon enoughbls0620 will become famous soon enough
Just to clarify.....
We connected several switches to the Cypress IO board and confirmed that the Classmate is reading the inputs correctly. However, when we tried to program on LabVIEW using Driver Station Get Digital Input.vi, we didn't get any feedback from the Classmate.(we can still see switches working on the Classmate though )
Unread 07-02-2010, 23:00
ligerbots ligerbots is offline
AKA: Elie GLik
FRC #2877 (Ligerbots)
ligerbots is an unknown quantity at this point
Send a message via AIM to ligerbots
would it be possible to just program your own dashboard and have that be your switch?
Unread 07-02-2010, 23:04
bls0620's Avatar
It is possible but that would be troublesome. Using customized dashboard means we would have to click on each buttons(using mouse pad, of course) during the matches, which we are not willing to do so.
Unread 07-02-2010, 23:37
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Are you sure that you are using the correct array indices?
The labeling of the Digital Inputs on the Driver's Station starts with 1, but the array indices likely start at 0 (I haven't checked this).
Unread 07-02-2010, 23:53
You still haven't said how you are determining that the value isn't being read. Are you probing any of the wires to find out whether the data from the Driver Station digital inputs is making it out of the Get Dig In?
I don't know why you're storing a string of text "1" and "0" characters in something called "Program Num", I am having a hard time understanding why you are doing a Concatenate instead of using the Append T/F String vi to do the appending it is designed for, and I have no idea why you put a Get Dig In there three times. Can you describe what that code is supposed to be doing?
Unread 08-02-2010, 23:04
FRC #0368 (TKM)
When we ran the code, to check the values, we turned on the 'highlight execution' and saw that the only value being read is 0.
I dont know why you're storing a string of text "1" and "0" characters in something called "Program Num", I am having a hard time understanding why you are doing a Concatenate instead of using the Append T/F String vi to do the appending it is designed for, and I have no idea why you put a Get Dig In there three times. Can you describe what that code is supposed to be doing?
There are 3 Get Dig In because we are using 3 switches. We are converting the value into string then concatenating them in order to create different combination for the case selector in autonomous. That way, we can have multiple autonomous modes and switch between them between matches without re-downloading the code each time. We are using the Append T/F String.vi to convert the digital input value into string.
ID:	8573  Click image for larger version
Unread 09-02-2010, 07:45
Try putting an indicator or a probe on the output of Get Dig In and running the code at speed.
Get Dig In returns all eight switches at the same time. You only need to use it once, and you can get multiple elements from its output with a single Index Array. See the attached code fragment. [edit]...which apparently didn't get attached properly, and which I do not have a copy of at the moment. I'll try to correct that later today.[/edit]
I understand that, but you're ignoring the "Append" part of it. You can build the string as you go instead of keeping the characters separate and combining them in a separate step.
Programming toggle switches to DS for different autonomous routines? grosh NI LabVIEW 9 30-03-2009 20:42
Problems with using 330's goal tracking code windell747 NI LabVIEW 11 16-02-2009 13:02
Using Limit Switches with the Arm iwin2000 Programming 3 18-02-2008 03:52
Problems with transmission using Inventor 8 Drew Hopman Inventor 4 10-01-2005 19:07
laser radar with BS2p using RS232 problems... chei_UCF19 Programming 6 26-02-2004 15:21
