Go to Post According to that logic, Engineers would say there will be twice as many spectators as needed, and we all know that's not the case! - Taylor [more]
Unread 07-02-2010, 23:53
Re: problems with using switches for autonomous
Originally Posted by ssica_jj View Post
Attached is a screen shot of our code.
You still haven't said how you are determining that the value isn't being read. Are you probing any of the wires to find out whether the data from the Driver Station digital inputs is making it out of the Get Dig In?
I don't know why you're storing a string of text "1" and "0" characters in something called "Program Num", I am having a hard time understanding why you are doing a Concatenate instead of using the Append T/F String vi to do the appending it is designed for, and I have no idea why you put a Get Dig In there three times. Can you describe what that code is supposed to be doing?
Unread 08-02-2010, 23:04
ssica_jj ssica_jj is offline
FRC #0368 (TKM)
ssica_jj is an unknown quantity at this point
When we ran the code, to check the values, we turned on the 'highlight execution' and saw that the only value being read is 0.
I dont know why you're storing a string of text "1" and "0" characters in something called "Program Num", I am having a hard time understanding why you are doing a Concatenate instead of using the Append T/F String vi to do the appending it is designed for, and I have no idea why you put a Get Dig In there three times. Can you describe what that code is supposed to be doing?
There are 3 Get Dig In because we are using 3 switches. We are converting the value into string then concatenating them in order to create different combination for the case selector in autonomous. That way, we can have multiple autonomous modes and switch between them between matches without re-downloading the code each time. We are using the Append T/F String.vi to convert the digital input value into string.
ID:	8573  Click image for larger version
Unread 09-02-2010, 07:45
Try putting an indicator or a probe on the output of Get Dig In and running the code at speed.
Get Dig In returns all eight switches at the same time. You only need to use it once, and you can get multiple elements from its output with a single Index Array. See the attached code fragment. [edit]...which apparently didn't get attached properly, and which I do not have a copy of at the moment. I'll try to correct that later today.[/edit]
I understand that, but you're ignoring the "Append" part of it. You can build the string as you go instead of keeping the characters separate and combining them in a separate step.
Unread 09-02-2010, 10:05
Are you using compatibility i/o or extended i/o?
Alan, you forgot the code fragment.
Unread 09-02-2010, 16:56
I thought it was there when I wrote the post this morning. Here it is (again).
Name:	Autonomous Select.jpg
Unread 09-02-2010, 23:12
FRC #0368 (TKM)
Smile Re: problems with using switches for autonomous
We tried what you suggested. It works! Thank you for your help! We really appreciate it.
Unread 14-02-2010, 17:07
fkm300 fkm300 is offline
fkm300 is an unknown quantity at this point
We are having similar problems with getting the PSoC inputs to be seen on the Dashboard. We have placed Get Dig In on the Dashboard.vi but don't see any states change. The states do change on the Driver Station. Does anyone have any suggestions on what we should do?
Thanks!
Komal
Unread 14-02-2010, 18:41
The Get Digital In vi only works on the robot. If you want to show its output on the Dashboard, the robot program will have to send it in the Dashboard data and the Dashboard program will have to retrieve it from there.
Programming toggle switches to DS for different autonomous routines? grosh NI LabVIEW 9 30-03-2009 20:42
Problems with using 330's goal tracking code windell747 NI LabVIEW 11 16-02-2009 13:02
Using Limit Switches with the Arm iwin2000 Programming 3 18-02-2008 03:52
Problems with transmission using Inventor 8 Drew Hopman Inventor 4 10-01-2005 19:07
laser radar with BS2p using RS232 problems... chei_UCF19 Programming 6 26-02-2004 15:21
