Go to Post All I wanted was a game hint.... :( - JohnBoucher [more]
Unread 07-02-2010, 10:46
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Team 95 progress so far
8" Mecanum drive, simple pneumatic kicker (with only half of the kicking pistons mounted so far) with welded sheet metal wheel brackets on a welded kit chassis. Using a cargo strap for ball control right now.
http://www.youtube.com/watch?v=quV24Sx0zpk
Let me know what you think!
Unread 07-02-2010, 10:59
whcirobotics's Avatar
whcirobotics whcirobotics is offline
FRC #1514 (Vikings)
whcirobotics is an unknown quantity at this point
Re: Team 95 progress so far
Nice idea of hitting from the side Great job ,
--did u guys make the code for the kicker, or is there a sample code?
Unread 07-02-2010, 11:28
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
We just have a button that opens the kicker solenoids, very simple. We hope to have an IR sensor that indicates when the ball is in the right position though.
I like the idea of side kicking because you get the widest possible kicker, and I can imagine our bot driving forwards and backwards through a zone and not having to turn to aim and shoot.
Unread 07-02-2010, 15:18
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
Kewl.
I hope you have a way to only allow the balls to go into your bot 3". The video shows the ball disappearing into your bot.
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 07-02-2010, 17:38
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
We plan on mounting some hard-rails that prevent that from happening.
Unread 07-02-2010, 21:12
FRC #1514 (Vikings)
So you guys have not programmed it, but using a button - hardwared-- to open the solenoids? when u guys program it plzzzzzzzzzzzzzzzzzzzzzz send me the code or help me out cause i have NO CLUE on how to program the kicker and i mean NO CLUE
Unread 07-02-2010, 21:50
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
No, we've got a button on the driver station that is programmed to fire the solenoids. We've got spikes controlled by the relay outputs on the digital sidecar controlling the solenoids. I *think* you can actuate the solenoids directly from the sidecar, but I'm not sure, we used the spikes because I was the last one to do pneumatics on the team (back in 2002 when I was still a student) and that's what I know works.
In any event, email me at jamesch13(at)gmail.com, give me some details, and I'll get you in touch with our programmer. It only takes about 5 lines of code, depending on what language you're using.
Unread 08-02-2010, 03:09
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Pneumatic Solenoids can be connected either to a Spike Relay module or to a Solenoid Breakout attached to a 9472 module in the cRIO slot 7 or 8.
Unread 08-02-2010, 09:27
chris janney chris janney is offline
FRC #3266
chris janney is an unknown quantity at this point
What does everyone think about a piston driven kicker. I guess the question I am trying to ask is, is there a better way?
Unread 08-02-2010, 09:31
synth3tk's Avatar
synth3tk synth3tk is offline
Volunteer / The Blue Alliance
AKA: David Thomas
synth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond repute
Grats on your working robot, that's definitely a unique design!
We could use some help, too. Our pneumatics work when handled manually, but I can't figure out how we're supposed to program the relays, or how to hook them up. There's really no good documentation on how to setup pneumatics in programming, specifically Java. I tried setting a joystick button to open the solenoid, but I don't think I'm doing it right.
The difference between theory and application is that in theory, theory and application are the same; In application, they are not.
Unread 08-02-2010, 09:33
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
I think the two best ways to go are piston driven or a cam driven spring release. I think pistons on a stick is the best way to go if you have limited resources (like no on-site machining, like our team ) and if you want the highest possible reliability. But if you have the ability to do a cam-tensioned spring system well, it will probably wind up being lighter and will definitely have more energy available to it through the whole match.
3136 Progress so far Nigel Robot Showcase 11 29-01-2010 17:44
Team 9 Progress hairrymonkeyman Robot Showcase 1 18-02-2006 23:38
Team 1918 Progress Packmon_driver Robot Showcase 4 31-01-2006 17:52
Team 75 Work in Progress gliebowitz Website Design/Showcase 11 03-03-2003 15:22
Team 84's progress evulish Robot Showcase 13 09-02-2003 22:08
