Go to Post Having 75% of the drive train without direct connection to the transmission would make me a bit queasy, but then again, I'm not Winnovative. - Taylor [more]
Unread 04-02-2010, 18:55
Chris is me's Avatar
AKA: Pinecone
pic: Team 2791 Coming Together
Unread 04-02-2010, 18:56
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Re: pic: Team 2791 Coming Together
This looks like the start to a quite successful robot. It looks very similar albeit different material to our still virtual drivetrain. Couple questions...How thick is the aluminum? Given the scalloping along the bottom why did you not use smaller wheels?
Overall though this looks great!
Mentor 2415
Unread 04-02-2010, 19:10
AKA: Pinecone
Thanks!
The aluminum plates are 3/16".
We went with 6 inch wheels and scalloping just for extra security with bump clearance. Some people on the team wanted to use the 2008 KoP wheels due to budgeting concerns, so using 6 inch wheels would have been cheapest too. Now that we're using 6 Plactions, it's not cheapest, but it still works. I'm guessing based on the question you guys are using smaller wheels?
Unread 04-02-2010, 19:12
AKA: Sean
Yup we are actually going with 4.5" wheels with the scalloped chassis as well. We went the custom route though on wheels so the cost wasnt a problem.
Did you think about direct driving one of the wheels instead of chaining all of them as well?
Mentor 2415
Unread 04-02-2010, 19:18
AKA: Pinecone
Thought about it, but the 8 wheels would make the gearboxes off center, making CoG a little harder to balance. Plus we're using dead axles (east coast drive).
Unread 04-02-2010, 19:20
AKA: Sean
Haha I love the east coast drive reference. We're doing dead axles too and wood frame again....Maybe that would be the down south drive.
Mentor 2415
Unread 04-02-2010, 19:42
GaryVoshol's Avatar
Cogito ergo arbitro
Make sure that the kicker is well-filed so it doesn't harm the balls.
(since 2004)
Unread 04-02-2010, 21:02
AKA: Pinecone
Thanks. Right now the angle piece has a very rounded edge, though the corners will be filed a bit more. I think we'll be playing with various slopes and wedges on it in the (dramatically shortened) tweaking part of our build.
Unread 08-02-2010, 01:58
Chris I finally realized which aspects of old MORT bots this looks like
Unread 08-02-2010, 07:50
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Chris,
What are the holes on the front of the kicker arms for?
Unread 08-02-2010, 13:29
AKA: Pinecone
I think the holes are left over from drilling at a slightly lower / crooked spot. Not exactly elegant, but it kinda sorta looks like weight reduction to me! Though now we're down to one mast instead of 2.
pic: Team 2791 Modular Chassis Sh1ine Extra Discussion 12 14-01-2010 19:01
Team 155 Techno-Nuts Coming Together lightningford54 Robot Showcase 0 09-02-2009 16:16
pic: Assistant Coach & Team Member working together :) amityschool Extra Discussion 7 06-02-2008 22:28
pic: FRC488 Chassis Coming Together Madison Extra Discussion 6 17-01-2007 18:18
Passover seder 4/7 -plans coming together archiver 2001 0 24-06-2002 02:49
