Go to Post You will find friends among all FIRST students who will become very good friends of yours, will care and help you with anything that you need help with. This is my personal opinion, If you are hooked, dont ever let it go. - Arefin Bari [more]
Unread 08-02-2010, 08:08
Re: Wiring JoystickGet Buttons to a custom VI
One of the cool features is to select the nodes you want to be in the subVI. Then move to the Edit menu and choose SubVI from Selection.
LV will make parameters for the wires that cross the boundary in and out, and put the nodes into the subVI along with constants and such.
You sometimes want to be careful doing this with control or indicator terminals, and sometimes LV will tell you that there is a reason you may not want to do this, but it is a helpful tool and helps to prevent making editing mistakes.
To do this by hand, by the way, you'd put the code in the subVI, and you'd have a broken wire as the Button input would be missing. You would place a control on the panel to provide the button value, and you'd right click on the panel icon in the corner to show the connector. Then you can click a spot on the connector and wire the control to it.
Greg McKaskle
Buttons, Buttons and more Buttons (2006) Freddy Schurr Team Organization 11 14-12-2005 21:36
Dumb question about wiring custom controls Adam Y. Electrical 1 18-02-2005 22:57
Wiring a Custom Operator Interface Box JWilliams101 Technical Discussion 2 12-02-2005 22:36
buttons rosebud Electrical 11 12-01-2003 02:02
Wiring custom toggle switches into operator interface DanL Electrical 9 13-02-2002 17:13
