labview delay help
hey, im relatively new and im using the classmate so pardon my grammar. im using labview to program our teams robot (1596!) and i need help with our camera tracking. ive recently learnt how to track the vision target but i need help because our camera (mounted on two servos) overshoots the target, is their any way we can adjust how fast the servo moves so that we dont overshoot the target.
Re: labview delay help
Hello 1596,
For adjust the servo moves, try to use the PID calculation that will smoothing the servo motion, or just lower the tracking rate. |
Keep in mind that while your typical Teleop loops are running at 50 Hz, the default code's image processing can maybe squeeze out 10 new target updates per second ... and as low as 2 per second when the camera is set to its highest resolution. (I'm referring to the default code here)
My team used the front panel from the FindCircles VI to observe almost 500msec when the camera is set to Hi-Res. Around 250 msec at medium res. And around 150 msec for low res. You can improve these times by changing the search window etc., but it's important to understand the timing differences of the control system, and the target detection updates. For the medium-resolution example, if you control the servos from within the Teleop VI, then you'll have approximately 12-13 "drive" cycles for each target update (250 / 20). So if you are adding an offset angle to the current angle, you'll probably overshoot the target unless the delta-angle is very very small. Our first attempts would overshoot greatly ... we reduced the delta "bump" angle to as low as 0.55 degrees per "correction" and finally got it to lock. (smaller values would result in the camera not even moving) Our next improvement to our tracker will probably involve taking the control commands out of the teleop vi and placing them with the other parallel tasks, and also waiting for the target variable to update before acting again. |
| Labview help | pedro696 | General Forum | 14 | 06-02-2010 19:34 |
| LabView Help Please | NumBeast | NI LabVIEW | 3 | 19-12-2008 15:11 |
| Delay Help! | waiakea2024 | Programming | 7 | 21-02-2007 12:41 |
| help: cannot get the picture in the labVIEW program .. (was: need help!! quickly!) | liad | LabView and Data Acquisition | 8 | 18-01-2006 12:20 |
| NEED HELP with Delay loop for compressor relay switch | archiver | 2001 | 10 | 24-06-2002 02:11 |
