Go to Post If you are content with where you are, you have celebrated the right things. If not, perhaps it is time to reconsider... what’s most important to you. - StephLee [more]
Unread 05-02-2010, 10:12
thatoneguy23's Avatar
thatoneguy23 thatoneguy23 is offline
Fiding everything we need to know.
FRC #2389 (Oklahoma STORM)
Team Role: Scout
thatoneguy23 is on a distinguished road
Tank Drive Joystick
Our Programmer is trying to put us into tank drive for our robot, but our second joystick is not responding to the program.
Could you guys give us some help?
Thanks
I think, therefore I am lost....- Me
"The difference between me and the rest of the world is sanity. They have it, I don't"
Unread 05-02-2010, 10:22
GEARmaster08's Avatar
GEARmaster08 GEARmaster08 is offline
FRC #0876
GEARmaster08 is an unknown quantity at this point
Re: Tank Drive Joystick
Did you make sure the Joystick is plugged into the correct USB port that you have it programmed for?
Unread 05-02-2010, 10:25
Team Role: Scout
Yes, we have made sure.
Unread 05-02-2010, 12:23
FRC #0876
What are you using for Programming?
Unread 05-02-2010, 16:30
hyperdude's Avatar
hyperdude hyperdude is offline
Techie.
AKA: Mike W.
FRC #2503 (Warrior Robotics)
hyperdude has a spectacular aura abouthyperdude has a spectacular aura abouthyperdude has a spectacular aura about
We've had the same issue, programming in LabVIEW. Both joysticks are communicating with the laptop, but are not with the program.
When we loaded the bot with Java, both worked fine.
Unread 05-02-2010, 16:45
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Ok, a list of questions:
1. Are you using game pads, or joysticks.
2. Have you cleaned out all the old joystick and drive references from the program?
3. Have you opened the joysticks in your Begin VI?
4. Have you confirmed that you are using the correct AXIS and wiring it into your motor set speed or the tank drive VI?
5. Have you connected indicators to the wire going from your joystick setref to your set motor speed in your teleoperated VI to confirm that your joystick is actually sending teh set motor speed VI a non-zero value?
6. Have you checked the diagnostics tab and noted any errors you might be seeing?
Unread 08-02-2010, 10:33
JohnFogarty's Avatar
AKA: @doctorfogarty
Tis a sad thing but just writing in the tank drive VI won't do it. I had to start from scratch to get tank drive to work
John Fogarty
Unread 08-02-2010, 21:04
zip100 zip100 is offline
FRC #0640
zip100 is an unknown quantity at this point
We had the same problem, we fixed it by placing pwm 2 to pwm 3.
Unread 08-02-2010, 21:28
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
It could be that the classmate is assigning the 2nd joystick to some other slot. In the setup page there should be a box listing the joysticks. Make sure they are on 1 and 2
Tank Drive vs. Omni Directional Drive jamie_1930 General Forum 9 24-01-2010 22:50
Tank Drive Sauce Programming 1 05-01-2009 18:50
Tank Drive Idaman323 Programming 14 15-02-2005 09:01
tank drive Stormhammer Programming 11 29-01-2004 23:08
Single Joystick Tank Steering archiver 2001 5 23-06-2002 22:49
