Go to Post SELECT YOUR STRATEGY BEFORE YOUR ROBOT DESIGN. - Kims Robot [more]
Unread 08-02-2010, 02:13
1747robotics's Avatar
1747robotics 1747robotics is offline
FRC #1747 (Harrison Boiler Robotics)
1747robotics is on a distinguished road
pic: 1747- Kicker Winch
Unread 08-02-2010, 02:15
Michael Corsetto's Avatar
Michael Corsetto Michael Corsetto is online now
Breathe in... Breathe out...
FRC #1678 (Citrus Circuits)
Michael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond repute
Re: pic: 1747- Kicker Winch
Sweet idea! Are you having any problems with the gear teeth breaking under the increased forces as they engage/disengage? How fast does it pull back/whats your kickers range? Show this baby on the final bot too please
Team 1678: Citrus Circuits - Lead Technical Mentor, Drive Coach **Like Us On Facebook!**
Unread 08-02-2010, 05:35
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Can you share the gear ratio of the gearbox? Standard Toughbox or custom?
Unread 08-02-2010, 07:00
Ben Martin's Avatar
Ben Martin Ben Martin is offline
Long Distance Mentor
FRC #0225 (TechFire)
Ben Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond repute
It is a modified toughbox, containing only a 14 tooth CIM gear (attached to the window motor) and a 50 tooth output gear. The cylinder disengages the gear, allowing a 6" IFI wheel attached to the output shaft (not shown) to spin freely.
We added more structure than what you seen in this picture to prevent the bottom plate from bending when the cylinder extends.
We will probably increase the cylinder bore size to 2", since the current one cannot hold the load we desire.
TechFire 225 -- Website -- Facebook
2015 & 2016 MAR Champions
Past teams: 234, 1747
Unread 08-02-2010, 09:10
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Holy bending angle bracket batman! You might want to consider cross-bracing on that bracket?
I like the idea though! What ensures that the gears re-mesh after a shot?
Unread 08-02-2010, 10:39
Ben Martin's Avatar
Only half the winch is shown in this picture; Believe me, we have a cross bracing on it now.
The bearing holes are slotted in the toughbox casing. So far, by just using that slot to guide the gear and extending the cylinder, we have had no problem keeping the gears engaged. The only issue we have is when a large force is applied, the gear sometimes skips.
Unread 08-02-2010, 10:44
We have not yet had teeth-breaking problems, but we are going to watch that closely.
We can load the kicker to its full strength in less than 5 seconds; hard numbers will come later. Our range is currently approximately 18' with a height of 2'. However, we are testing foot designs/angles to see what works best.
Will do. Come to BMR, Buckeye, or Atlanta and see for yourself!
Unread 08-02-2010, 11:05
Brandon Holley's Avatar
Very interesting take on a clutch mechanism. I'd like to see some video of it in action if you have any.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 08-02-2010, 12:04
Josh Drake's Avatar
Josh Drake Josh Drake is offline
Engineering Mentor
FRC #5403 (Aluminosity)
Josh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond repute
For anybody having issues with kicker winches, these little window motors work great Of course they don't back drive unless you really pull on them.
07'-10' FRC 343
11'-12' FRC 2751
13'-14' FRC 3494
15'-16' FRC 5403
Unread 08-02-2010, 12:06
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
The little window motors don't do much work, compared to a CIM, so you might need to wait around a while for it to winch up your cable
Unread 08-02-2010, 12:17
Josh Drake's Avatar
Engineering Mentor
Agreed, we used the CIMs and Fishers on ther things, so I had a choice of pneumatics, the 555 or the window. The 555 is pathetic. On our system the window motor is directly coupled to the shaft, and takes 3 seconds to winch back 70 pounds. Ball is going 40 feet at 9 feet at it's highest point. Of course we just go off half cocked to shoot closer to the goal.
07'-10' FRC 343
11'-12' FRC 2751
13'-14' FRC 3494
15'-16' FRC 5403
Unread 08-02-2010, 18:05
Steve G.'s Avatar
Steve G. Steve G. is offline
FRC #2549 (Millerbots)
Team Role: Student
Steve G. is an unknown quantity at this point
Send a message via AIM to Steve G. Send a message via Yahoo to Steve G.
Question Re: pic: 1747- Kicker Winch
What is the length of your pneumatic cylinder? What is the bore measurement?
Unread 08-02-2010, 18:14
Bob Steele's Avatar
AKA: Bob Steele
Be careful of calculating the frictional forces on the gear you are pulling.
Are you pulling a dog gear ??
We are using a similar system but using 2 pneumatics ... the dog gear winds the capstan and the tension is held by a ratchet and pawl... we then pull the dog gear with a pneumatic and release the kick with the 2nd pneumatic which releases the pawl.
Our design engineer thought that the friction in the dog gear would be too great to pull effectively with a short throw pneumatic.
good luck..
cool design..
We are winding with a Banebot transmission and a FP motor.
Unread 08-02-2010, 21:55
Ben Martin's Avatar
No, we are just disengaging a 50-tooth gear. We used parts from an old AM Gen 2 and an off-the-shelf ratchet to test the dog gear-ratchet approach, but like you said, the friction forces prevented the dog gear from disengaging. After trying a number of things (like beveling down the "teeth" of the dog gear), we switched to this idea.
It is a 1.5" bore cylinder with a 1/2" throw.
Unread 09-02-2010, 22:57
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
It's been a little while since I've seen a mesh-shifter in FIRST, and this is about as close as I've seen recently. Definitely cool, used to be a lot more stuff like this in FRC.
pic: Winch for Kicker MrForbes Extra Discussion 10 10-02-2010 10:42
pic: 1747 Teaser 1747robotics Extra Discussion 3 07-02-2010 23:57
pic: Buckeye: 1747 Panda Pose Dan 1038 Extra Discussion 9 03-03-2009 17:23
pic: 1747 Turret Close up Allison Robot Showcase 2 20-02-2007 10:16
pic: Vex Winch AdamHeard Extra Discussion 5 16-11-2006 23:30
