Re: Making Clothing! HELP!!!
You could model some clothing and apply the "Garment Maker" modifier to a "pattern" of clothing. The garment maker works with the cloth modifier to create a reasonable simulation of clothing as it should deform over an animated body. This process requires a little work, but it works nicely. If you go to the HELP menu in max and type in garment maker, it will give you a walk-through on how to use it. Typically garments can be added to a character after the character has been animated because the cloth needs to be "simulated" or deformed per frame. Give that a shot, or you can just model the clothes right on the character and normal map them just like they do for video games.
Ben LaCount Autodesk Certified Instructor |
| Need help making water | supertetelmanma | 3D Animation and Competition | 3 | 11-02-2007 19:42 |
| Help - Making the autonomous mode | razer | Programming | 5 | 31-01-2007 16:25 |
| HELP!!!!!! LABVIEW IS MAKING ME MAD!!!! | cdennisxlx2 | LabView and Data Acquisition | 2 | 21-03-2006 21:50 |
| Making a Dongle - Pin 1 help | DanL | Electrical | 6 | 05-03-2003 16:58 |
| I need help w/ making an Invitational | Matt Attallah | General Forum | 6 | 14-05-2002 19:48 |
