Go to Post You're on a team, weren't you taught Gracious Professionalism? It doesn't only apply to competitions, it applies to the real world. - Zac Schofield [more]
Unread 08-02-2010, 15:30
grosh grosh is offline
FRC #2147
grosh is an unknown quantity at this point
Jiggly servo
We have a two speed transmission that shifts with a servo. We want to press the trigger button to shift between high and low gear. We want the program to Get the Servo angle...decide if it is in high gear (45) or low gear (120)...then shift into the opposing gear.
The problem with the program- program attached below- is... when we pull the trigger button the servo JIGGLES before it decides what gear it sets in. Most of the time it chooses the correct gear but not always.
Are we taking the wrong approach?
servo on DS eitang FRC Control System 1 16-01-2009 14:32
Servo Strength TJ4nier Motors 20 13-02-2007 02:59
Servo behavior question / advanced servo/PIC programming question DanL Electrical 12 18-10-2005 18:33
Buying Servo Gamer930 Motors 4 13-02-2005 20:44
Servo MASherry General Forum 6 04-10-2004 22:46
